Rear Window Defroster
  • 3039 Views
« on: July 08, 2006, 06:13:02 PM »
Okay, I now have a hard top on me 2dr and the question is.
The hardtop has a defroster.
Can I just hook a switch to it
or
does it need to have resistor installed (or a whatnot)as not to
over power it?
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
Re: Rear Window Defroster
« Reply #1 on: July 08, 2006, 06:49:39 PM »
No resistor needed, but make sure the wiring is heavy duty, like 10 gauge, and make sure the switch can handle at least 30 amps. Plus, don't forget to turn it off after the window is clear, otherwise you're wasting a ton of electricity that will put a drain on your battery and alternator. That's why factory defroster grids usually have a timer switch...
Offline tOnKa TrAcKeR
  • 264
  • support our troops
    • Cardomain site
« Reply #2 on: July 08, 2006, 08:39:12 PM »
actually just get you a factory rear defroster switch...the wires are already there...pull your right taillight and there is the connector for the rear defrost...at least thats how it is on my 90 and 91
Offline biker
  • 730
  • It's a sickness I tell ya
« Reply #3 on: July 08, 2006, 10:27:35 PM »
I used to have a factory switch kicking around here. If I can find it it's yours
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
« Reply #4 on: July 09, 2006, 08:12:05 AM »
Sweet. Thanks.
The wires for the rear defroster don't look that heavy.
I'll pull the tail light today and se what i have back there.
Offline biker
  • 730
« Reply #5 on: July 09, 2006, 06:44:35 PM »
Good news, 8) I found it today so PM me your mailing address and I'll drop it in the mail to ya
99 Vitara 2wd
10 Gr Vitara
