Can I use a sami ARB in my kick´s front axle???
  • 1696 Views
Offline garbage!!!
  • 63
  • IFS PRIDE!!!
    • my truck's zukiworld page
« on: July 10, 2006, 07:27:34 PM »
That is just that...
I want to use a Sami ARB on my sidekick´s front axle( stock).
can it be adapted?
           Gui
mudding aroung : ) in counryside São Paulo.
Offline cj
  • 1276
  • I drive a really big ATV
Re: Can I use a sami ARB in my kick´s front axle???
« Reply #1 on: July 10, 2006, 07:41:38 PM »
http://www.arb.com.au/alac/alsp/Air_Locker_S&P_Manual.pdf
This shows all the parts and numbers of every air locker. You can see what you have and compare it to what you want and work out which parts you will need for the swap.
Offline cj
  • 1276
« Reply #2 on: July 10, 2006, 07:43:27 PM »
You need to click on the Enter on the cover and then click on the red numbers in the list.
« Reply #3 on: July 10, 2006, 11:54:08 PM »
I think it depends on the year.  I used a Tracker front diff in a set of Sammy axels, so it should go the other way.
If you do though, I would switch to the Sammy diff.  Get away from the aluminum, there are a few shots of them breaking apart on here.
« Last Edit: July 10, 2006, 11:57:40 PM by Drone637 »
