Twin Stick for Track/Kick
  • 23 Replies
  • 6059 Views
Offline Quaddawg
  • 1622
    • My Ebay Store
« on: July 11, 2006, 06:24:37 PM »
OK, I saw one at the Melt, heard the guy had some for sale.. then completely forgot who had them!!!
Was it Stan??
How much?
When can I get a kit?
Anyone know?  It's this or a 2wd low from RRO, and I would loads rather have the Twin Stick..
Offline ROSS
  • 1412
Re: Twin Stick for Track/Kick
« Reply #1 on: July 11, 2006, 06:35:45 PM »
stan is making them
Offline locjaw
  • 2045
  • 22
« Reply #2 on: July 11, 2006, 08:36:48 PM »
yep, 37kicker (stan)makes them, and they are bitchin
jason
Offline JayN
  • 220
« Reply #3 on: July 11, 2006, 09:03:53 PM »
more info would be cool
96 sport, safari rack, lift
1970 gmc truck
1950 dodge truck
1974 corolla
« Reply #4 on: July 11, 2006, 09:09:22 PM »
It's a twin stick too  ;D
Offline track_this
  • 332
« Reply #5 on: July 12, 2006, 01:33:03 AM »
hey stan chime in here :D
calmini 3 inch sus. lift
rear lockright
31" kumho m/t's
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #6 on: July 17, 2006, 08:02:58 PM »
Stan cant get online right now. He has a new internet service and lost his password or something. I will try to get some pics for you guys in the near future.
Mike
Offline Maroon Monsoon
  • 876
« Reply #7 on: July 18, 2006, 12:38:16 AM »
are the T cases on 2nd gens similar enough or the same as 1st gens? what I'm getting at is I wouldn't mind a twin stick either
Offline Jimiweld
  • 234
    • www.fullfusion.ca
« Reply #8 on: July 18, 2006, 06:12:55 AM »
I'd like to know more about the twin sticks as well. I gather this is another method of gearing to allow larger tires, is this correct?
« Reply #9 on: July 18, 2006, 07:58:34 AM »
Nope, it allows you to have 2WD in low range
and shift from 2 hi 4 hi and 4 lo 2 lo without going
through the whole T-case shifting pattern
Offline Quaddawg
  • 1622
    • My Ebay Store
« Reply #10 on: July 18, 2006, 08:45:34 AM »
Also, it allows you to have the front engaged, and the rear disengaged..  so you can do burn turns (lock the rear brakes, and pull yourself around with the fronts engaged..) great for tight trails and rock crawling.
Offline Jimiweld
  • 234
    • www.fullfusion.ca
« Reply #11 on: July 18, 2006, 09:15:20 AM »
Ok, that sounds interesting, is it a complicated set up?
Just curious, it's way too expensive for me but the Calmini website offers rock crawling gears for the T-case.  If you had a set of these in then would you be able to run larger tires 33-35".
If you put these in could you still drive it at normal highway speeds in 2 wheel hi?
Thanks
Jim
  • 876
« Reply #12 on: July 18, 2006, 10:15:58 AM »
wow, you can have the front engaged and the back disengaged? holy crap, what a versitle setup. someday I think I should do this to my GV
Offline ADavis
  • 209
    • Aaron's Webpage
« Reply #13 on: July 18, 2006, 10:16:48 AM »
The Calmini gears do not effect your 2WD speeds.  In 4Lo, you can easily run 33 and probably 35's.  I have 31's with the 4.24 T-case and 5.62 Dif gears and I litterially idle up stuff that before took a heavy right foot to tackle.
Aaron
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #14 on: July 18, 2006, 02:54:38 PM »
Thats actually not entirely true. The Calmini t case gears do not effect the high range. If you have a twin stick you can shift into 2 low. The tracker case does not allow you to disengage the rear, even with a twin stick.
Mike
