kick gears in sami, Highway driving?
  • 2257 Views
Offline Awsume Suzi
  • 6
  • I Love ZUKIWORLD!!
« on: July 12, 2006, 02:56:15 AM »
hey, does any one know what a 1.3L samurai with stock t-case and 31" tyres would rev like at 60mph/100kph with the 5.12 ring and pinion kick/vitara gears in, would they be to low for offroad as well as highway driving? or would the 4.30 kick gears be better suited on/offroad ;D? Just brought my first samurai, its a bit of a shiny lol  :P
« Last Edit: July 13, 2006, 03:53:08 AM by Awsume Suzi »
Offline hotwired
  • 17
Re: kick gears in sami, Highway driving?
« Reply #1 on: July 12, 2006, 03:23:57 AM »
 Go to izook.com, there's a gear calculator in the tech section that should give you an answer.
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
« Reply #2 on: July 12, 2006, 11:06:24 AM »
5.12's will be to steep for those tires if you plan on driving it highway speeds.  33's would be lowest size for 5.12's
4.62's are good diif gears for 30-31's gives u 20% reduction in high and low, and brings back 5th gear.
Offline Awsume Suzi
  • 6
« Reply #3 on: July 12, 2006, 04:11:39 PM »
Think i will buy some 4.30 kick gears, would the 4.30's ring and pinion be good for 31's with out doing any thing to the t-case?
Updated:  I just look at the gear calculator at http://www.izook.com/gearcalc.htm
and it worked out that it would do 56mph at 3500rpm with the 5.12's in 5th gear, stock t-case and 31's on. that is fast enuff for me on the high way. Does that sound correct?
thanks for the replys
« Last Edit: July 12, 2006, 06:04:23 PM by Awsume Suzi »
Offline john1974
  • 617
    • Zuknation
« Reply #4 on: July 12, 2006, 06:14:45 PM »
doesnt sound right to me I think it would be reved out with 5.12's and 31's with 4.62's and 31's at 60 your around 3800 rpm
« Reply #5 on: July 12, 2006, 11:46:28 PM »
it looks correct on the rpm and will only go to 3900 with 4 to 1's if you change them down the road, the stock motor will rev real high all day long so your good to go.
