coils for a kick
  • 2158 Views
Offline JayN
  • 220
coils for a kick
« on: July 12, 2006, 02:31:01 PM »
i should have next week a front sami axle set up for a 3 link. i am doing the samin axle to save some costs fo rnow, as i can use my kick third up front and  i am getting the whole set up pretty cheap. my question is? what are some good coils for the front of  a kick ?
thanks, it is going into my 90 2dr.
96 sport, safari rack, lift
1970 gmc truck
1950 dodge truck
1974 corolla
Offline beerman
  • 339
  • Suzuki 4x4 Norway
    • www.tristania.com
Re: coils for a kick
« Reply #1 on: July 12, 2006, 02:59:40 PM »
saab 9000 springs will give you a 2" lift with the oem front axle, but not sure with a sammie axle.
you can also use Merchedes springs in the front and Audi80 in the rear, these are softer and gives a little more lift. these coils needs to be cut a little bit.
i think nissan 180 will fit in the rear?
or you can use GVsprings, gives 2" lift but are stiff.
you can check out:
http://www.angelfire.com/ns2/brookst/coil.html
« Reply #2 on: July 13, 2006, 05:05:50 AM »
Stock rear coils should work OK on the front with a beam axle. Suzuki quote the effective spring rates front and rear as 157.5lbs/in so stock rears will give the same spring rate as the stock IFS front.
Offline Maroon Monsoon
  • 876
« Reply #3 on: July 13, 2006, 01:51:08 PM »
maybe some coils off a jeep of some sort. since it's a completely custom setup you are going to do you just need to make sure you'll have the spring rate you want and you should be set
  • 876
« Reply #4 on: July 13, 2006, 01:52:58 PM »
I think I'm right on that one, not sure
Offline chet
  • 556
  • Zuki time!
« Reply #5 on: July 13, 2006, 02:04:25 PM »
what was being used on the previous rig? stock rears may work but may be too short depending on the lift you want.
