Lift Idea
  • 2926 Views
Offline biker
  • 730
  • It's a sickness I tell ya
Lift Idea
« on: June 22, 2005, 04:24:20 PM »
I have read a little on here about using GV V6 coils in a tracker to gain a little lift. Has anyone here done this and how was the ride and flex? Any pros or cons?
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
Offline 1bigtracker
  • 3409
Offline echojeff
  • 414
  • Lo que sea
Re: Lift Idea
« Reply #2 on: June 23, 2005, 04:59:29 AM »
Which is better, new coils (GV or ford van coils), or just use coil spacers?
Jeff
« Last Edit: June 23, 2005, 06:35:07 AM by echojeff »
95 Kick 4dr JLX.
Offline chet
  • 556
  • Zuki time!
Re: Lift Idea
« Reply #3 on: June 23, 2005, 06:21:28 AM »
I read about honda accord coils in the rear work as well?  ???
Offline Mythose
  • 361
Re: Lift Idea
« Reply #4 on: June 23, 2005, 09:59:40 AM »
Were does one get camber bolts fo fix the camber? i think i will do this to my 2dr sidekick.  and accompany it with about a 3inch body lift, to give me a tital of 5 to 5.5 inches and probly all under a $100. plus 40 for the snorkel,
then a locker,  yeah ok it will look a lill funny till I get 30IN tires to put under it  found thoes for $100  each for
30X9.5x15 with desently agressive tread.
What type of straps should i use to limit the down travel so it  dont thrash the CV'S?
Offline Chief
  • 678
  • Whaddya lookin at??
Re: Lift Idea
« Reply #5 on: June 23, 2005, 10:03:24 AM »
Limit straps...LOL!  ;D
I run a 2" strut spacer on the fropnt of mine, with no problems as of yet. if you are just doing a strut plate flip, I wouldn't worry about a limiting strap.
Offline bus_driver
  • 479
  • the voices tell me different things
Re: Lift Idea
« Reply #6 on: June 23, 2005, 04:31:23 PM »
where do you find 2000 gv springs from ????
I will do this and the strut mount flip with xj springs in the rear with crown vic shock.....this would work awesome!!!! for me
92 2dr soft top
2-1/4" cherry bomb exhaust
235/75/15
2 inch lift
custom mud
Offline 92Sidekick4x4
  • 1456
Re: Lift Idea
« Reply #7 on: June 23, 2005, 05:14:45 PM »
probably a wrecker, or hawk
