four wheel drive
  • 9 Replies
  • 3024 Views
Offline sidetracker17
  • 11
  • double trouble suzuki's
four wheel drive
« on: July 19, 2006, 09:32:16 PM »
i have a 1989 suzuki sidekick and it wont lock into four wheel drive could anyone tell me what the problem is!!
                     it shifts into 4wd but the front wheels arent turning
« Last Edit: July 20, 2006, 05:32:29 PM by sidetracker17 »
1990 suzuki sidekick- american racing wheels and cold air intake.
1989 suzuki sidekick- 31's, welded spider gears
1988 suzuki samurai- sprung over with 31's
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
Re: four wheel drive
« Reply #1 on: July 20, 2006, 09:10:41 AM »
Not without some more information we couldn't... ::)
« Reply #2 on: July 20, 2006, 09:57:29 AM »
Has it got Free Wheeling Hubs they sometimes seize but can be regreased.
Offline purevil71
  • 261
  • Someday when I grow up, I wanna be hardcore too!!
« Reply #3 on: July 20, 2006, 10:10:42 AM »
is it, "T-case goes into 4wd, but front tires aren't pulling", or "won't shift into 4wd at all"?
88.5 Samurai
Balls Deep 4x4 & Off-Road
I-Zook Staff
  • 11
« Reply #4 on: July 20, 2006, 05:37:53 PM »
when i shift it into 4wd and turn the hubs to lock it still just spins the rear wheels and not the front ones.
« Last Edit: July 20, 2006, 05:46:12 PM by sidetracker17 »
Offline ruin9fy
« Reply #5 on: July 20, 2006, 05:53:05 PM »
Sounds like the problem i had with my tracker win i first got it id regrease ur hubs first easy to do
a couple of sockets and a allan key in like 8mm i think id clean with degreaser and some WD40  too and use a old tooth brush if u dont have a wire one that will fit in the space needen cleenen then just get a tub of valvoline uneversal grease.
grant
96 tracker first mod 2157515 wildcountry EXT on gloss black samy rims
Offline Digger
  • 1991
« Reply #6 on: July 21, 2006, 02:04:45 PM »
Yeah, sounds like your hubs aren't engaging right, probably stuck. When you lock the hubs in and leave the tcase in 2wd, engine off, parked with the brake on, reach under the front end and try to turn by hand each front cv shaft. neither should be able to turn, but if one or both does, then that's the hub that needs cleaned out and relubed...
Offline purevil71
  • 261
« Reply #7 on: July 22, 2006, 11:26:39 AM »
lock them in, tap them with a BFH and see if the break loose.  Sometimes that works, other times you just need to take them apart and clean them really well (which would be a good idea either way).
88.5 Samurai
I-Zook Staff
  • 11
« Reply #8 on: July 25, 2006, 08:49:16 AM »
i did what you said and took them apart and cleaned them and that did the trick
        thanks for your help
« Reply #9 on: July 25, 2006, 09:27:24 AM »
Another neglected and corraled to the street
SideKick has been set free to roam the hills  ;D
Evil Seeds planted
Our job is done here
