Survey
  • 3058 Views
Offline fullsink18
  • 250
  • Wheel Me!
Survey
« on: July 21, 2006, 12:13:18 PM »
Hey everybody I got kind of bored at work and decided to make a survey togather all types of information about everyones suzukies.  The survey is broken down into 2 parts (cause survey monkey only allows ten questions).  So if you feel like it fill in the survey.  If you have more than one vehicle you can fill in the survey for each vehicle.
Part 1http://www.surveymonkey.com/s.asp?u=912182387981
Part 2http://www.surveymonkey.com/s.asp?u=759862388517
Thanks a ton.  After I get all the information in I will share the link with the charted / compiled information.
94 2dr kick 8v
-     Full set of Calmini's skid plates, calmini header and full exhaust, k&n filter, sky idler arm, calmini idler arm brace and truss with stabalizer, lock-rite rear locker, Calmini 3"  BL, 2" Digger Spacers, Shrockworks bumper, chicago electric 8,000lb winch, 31" Grabber AT2, 15x7 2
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
Re: Survey
« Reply #1 on: July 21, 2006, 01:43:44 PM »
Done for my 3...
Re: Survey
« Reply #2 on: July 21, 2006, 02:31:15 PM »
Done.  I'm suprised you didn't have a spot for transfer case gear ratio along side the diff gear ratio.
Re: Survey
« Reply #3 on: July 21, 2006, 08:26:35 PM »
   Done for our 3!
Offline CJ11
  • 157
  • 95 SIDEKICK ON 31'S
Re: Survey
« Reply #4 on: July 21, 2006, 09:37:53 PM »
I'm in I only have one now brought my other to grave yard.
Offline purevil71
  • 261
  • Someday when I grow up, I wanna be hardcore too!!
Re: Survey
« Reply #5 on: July 22, 2006, 11:23:16 AM »
I just put it all under the same thing.....lol
88.5 Samurai
Balls Deep 4x4 & Off-Road
I-Zook Staff
Offline fullsink18
  • 250
  • Wheel Me!
Re: Survey
« Reply #6 on: July 24, 2006, 06:09:19 AM »
Transfer case gears.  *Noted*
I knew I missed something
Thanks for the recommendations. Any more i'll make a list for the next time.
Also thanks everybody for filling this out.  I figured it would be pretty interesting.
94 2dr kick 8v
Offline SiKiD_01
  • 574
  • Fully Sik, Flying Vit.
Re: Survey
« Reply #7 on: July 24, 2006, 07:56:26 AM »
just done for my vit, but it seemed like my vit was stock as i filled in the survey with only the drop down options. a zook is fully custom when you can't pick from drop down options and need to fill in "other" in space provided.
anyway, it was fun, and should be good to see the end results.
cheers.
Offline fullsink18
  • 250
  • Wheel Me!
Re: Survey
« Reply #8 on: August 01, 2006, 10:19:17 AM »
The surveys are now closed.
http://www.surveymonkey.com/DisplaySummary.asp?SID=2423961&Rnd=0.7977789
http://www.surveymonkey.com/DisplaySummary.asp?SID=2423960&Rnd=4.427433E-02
That is the two locations of the surveys.
You may need to login so here is the Username: suzukisurvey|removethispart|@gmail.com
                                                           Password: sidekick
Any question that had typed response you will have to click on the view button next to that question.  There is also a button at the top called "View Detail" which will so all the input from one person.
Thanks again everyone for the input.  If these links dont work or you have trouble let me know.
94 2dr kick 8v
