recharging air conditioner...
  • 2197 Views
Offline ddevil
  • 155
« on: July 22, 2006, 10:22:20 AM »
how hard is it to recharge an ac system?  the newer r134a or whatever it is.  my buddy at work told me there was a "kit" at walmart for like $30 to recharge it...  would one of these "kits" work for my '95 tracker?
mike
'95 geo tracker 2dr 5spd soft top with 2" suspension lift
Offline TN_Tracker
  • 1113
    • TN Tracker's Suzuki Space
Re: recharging air conditioner...
« Reply #1 on: July 22, 2006, 02:08:45 PM »
It's really a no-brainer if the system only has a small leak and is 134a. Here's what I use:
More info here: http://www.id-usa.com/default.asp
Offline legionnair
  • 94
  • I hate working lets go wheeling
« Reply #2 on: July 22, 2006, 02:23:25 PM »
It will work but remember to look up the required pressure for the system you dont want to run with low refridgerent or to much of a charge
call your local suki dealer and ask for the proper charge pressure
Dustin
OOps, owell thats just the fender
Offline ddevil
  • 155
« Reply #3 on: July 22, 2006, 03:05:09 PM »
cool<pun intended> :P
Offline Quaddawg
  • 1622
    • My Ebay Store
« Reply #4 on: July 22, 2006, 06:32:19 PM »
Yes, if you still have decent pressure, you can use that kit, as long as you make sure you don't over fill it.  But if you have no pressure, you should vacuum the system down, and see if it holds, if it doesn't  you will need to pressurize the system with nitrogen, (or something..) and check for leaks with soap bubbles. Usually it's the seal on the compressor.
If it is just low on freon, grab a freon can with gauge type hose as above and give it a try..
Offline ddevil
  • 155
« Reply #5 on: July 22, 2006, 11:08:12 PM »
i think it may just be low.  it works but i know it's not as cold as it should be.
mike
