suzuki Escudo
  • 3436 Views
Offline Suzuki1.8
  • 283
  • Tires so low looks like i'm riding on blades
suzuki Escudo
« on: February 01, 2005, 12:10:27 PM »
Hey this might sound Dumb But I know Escudo are the same thing as sidekicks, but they have a option for a v6 in there sport like model. Here is my question. Can you get Escudo in the united states with a left hand drive? Cause the only thing i can think of better then my 4 cylinder is a 2.0 v6.
Offline SnoFalls
  • 1358
Re: suzuki Escudo
« Reply #1 on: February 01, 2005, 01:05:53 PM »
On my vacation, we had a port call at the british west indies (tortola). So many zuks it was scary (easily half the vehicles were zuks). The couple of escudo's I saw I wished I could take one home :)  ... and yes, escudos are LHD (or RHD) ... none in US :(
Offline Charlie
  • 77
Re: suzuki Escudo
« Reply #2 on: February 01, 2005, 04:29:56 PM »
V6 never made it to the US, couldn’t pass the emissions tests.
Charlie
Offline Suzuki1.8
  • 283
Re: suzuki Escudo
« Reply #3 on: February 02, 2005, 01:17:20 AM »
I did some looking on ebay on found the 2.0 v6 from a escudo for sale, and the all wheel drive tranmission. I wonder how easy that would bolt up? The vaction surrounded with zuks sounds like a good dream. I wonder if someone would import a escudo v6?
Re: suzuki Escudo
« Reply #4 on: February 02, 2005, 07:45:46 AM »
From what I've seen and read the 2.0V6 engine was fitted in the non-US version of the Sidekick Sport. The frame rails are wider so its not a direct bolt in but I have seen one fitted in an earlier Track/Kick. I think its a detuned Mazda engine. The transmission is the same but you would probably need the V6 bellhousing
Offline Suzuki1.8
  • 283
Re: suzuki Escudo
« Reply #5 on: February 02, 2005, 08:01:39 AM »
It would be no problem since i have sidekick sport with the 1.8. I imagine i would need the ecm and wireing harness to.
Offline Suzuki1.8
  • 283
Re: suzuki Escudo
« Reply #6 on: February 03, 2005, 01:20:41 AM »
So after much searching. I found the Suzuki Escudo is only rated at 102.97 nm with equals 138 hp so its only a 18 hp increase from a 1.8 its torque is not much bigger either. Plus its rated at lower gas milege, but then on 18 hp could be a big difference in power in a kick. Has any one ever got to drive both a 1.8 kick and 2.0 Escudo to compare? ???
Offline mbmarkyb
  • 461
    • UK Vitara
Re: suzuki Escudo
« Reply #7 on: February 03, 2005, 03:10:14 AM »
Didnt the v6 2.0 have a hyd clutch rather than a cable, i know the v6 2.5 has as i often dream.  I also think the t/ case is slightly different so maybe an adapter plate to house the stock transmission would be the way forward,
Markyb (UK)
UK Vitara JLX SE
Offline Suzuki1.8
  • 283
Re: suzuki Escudo
« Reply #8 on: February 03, 2005, 03:14:09 AM »
The 2.0 v6 does have a hyd clutch. So does the sidekick sport 1.8 and they share the same wide frame and tranmission and t case
