Diff Spacer
  • 12 Replies
  • 3709 Views
Offline TysonS
  • 383
  • www.funinbc.com
Diff Spacer
« on: July 24, 2006, 06:10:20 PM »
Hey, I'm looking for some pics of rear diff balljoint spacers.  I don't have a access to a welder and im wondering what can be made?  If you used a welder, post them anyway please.
thanks yo. .  8)
Offline safarikick
  • 270
  • nor-cal rhinos
Offline biker
  • 730
  • It's a sickness I tell ya
Re: Diff Spacer
« Reply #2 on: July 24, 2006, 09:41:31 PM »
Here's the one I built, 3/8" plate top and bottom and 2" .250 wall square tube inbetween
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
Offline ddevil
  • 155
Re: Diff Spacer
« Reply #3 on: July 25, 2006, 02:49:38 PM »
the guy i got my coil spring spacers off of also made a 2" spacer for me out of the same material as the spring spacers, uhma or whatever it is :P  i had to enlarge the bolt holes slightly but other than that it works beautifully :D
mike
'95 geo tracker 2dr 5spd soft top with 2" suspension lift
Offline chrisvitarasport94
  • 228
Re: Diff Spacer
« Reply #4 on: July 25, 2006, 11:22:19 PM »
I had a solid block spacer at first but the bolts are long and can't take the strain, resulting in them failing and the spacer falling out on articulation; a real get me home nightmare!
I good guy in my club then made me a  2" 3 piece one as above, with the 4 original bolts 9 1 is shorther thatn the othr 3) and 4 new short ones - much better, and a worthwhile modification
Offline Geared
  • 17
Re: Diff Spacer
« Reply #5 on: July 29, 2006, 05:38:15 AM »
Kick me behind if this is at stupid question, but why lifting the balljoint?
88/90 mod Vitara 3dr hard-top.
1600 8v injection with Green filter.
3 inch suspension lift, 3 inch bodylift.
AVM locking hubs in front, Lockright rear locker.
33x12,5x15 Trxus mud tires.  My virutuell garage on www.offroad.no on this link: http://www.offroad.no/garage.asp?page=ShowID&ID=1563
Offline SnoFalls
  • 1358
Re: Diff Spacer
« Reply #6 on: July 29, 2006, 06:54:46 AM »
so it won't bind up.
(a suspension lift and longer shocks can cause the joint to bind when the axel droops).
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: Diff Spacer
« Reply #7 on: July 30, 2006, 06:14:42 AM »
http://www.cabrito.suzukioffroad.com.br/Upper%20wishbone.htm
Also try a search for dif block at Ack's FAQ. Written in English with pics and torque values.
Ack
Offline CJ11
  • 157
  • 95 SIDEKICK ON 31'S
Re: Diff Spacer
« Reply #8 on: July 30, 2006, 01:13:48 PM »
How many people use this and is it a mod that should be done or can I live with out it as I have been doing
Offline ack
  • 1659
    • Ack's FAQ
Re: Diff Spacer
« Reply #9 on: July 30, 2006, 07:12:36 PM »
My impression is that you will eventually bend the #$%# out of that pivot joint especially if you do anything nastier than simple #1 or #2 trails.   Now guys like me who are contemplating a Digger lift on my 4-door DD may put off installing one for a while...
Ack
Re: Diff Spacer
« Reply #10 on: July 31, 2006, 04:33:55 AM »
Its a good mod to do. IIRC shocks up to 2" longer than stock will be OK but longer than that and the ball joint will bind. There is a strong possibility that a binding ball joint will fail and that can do a lot of damage as well as leaving you stranded on the trail. Also it gives a better angle on the upper arm which should reduce axle tramp. Interestingly, when I fitted the rear parts from my Calmini kit, both the lower control arms and the upper wishbone bolted directly on without having to move the axle at all. The Calmini upper arm has the rose joint but the only other difference is the distance from the arm to the mount on the diff, its like having a built in spacer.
« Last Edit: July 31, 2006, 04:38:30 AM by Rhinoman »
Offline CJ11
  • 157
Re: Diff Spacer
« Reply #11 on: July 31, 2006, 02:03:19 PM »
Is anyone making these because I will buy it do not have the time to try make one now let me know... Thanks
Offline okezuki
  • 51
Re: Diff Spacer
« Reply #12 on: July 31, 2006, 04:26:46 PM »
get ahold of safarikick on this board, he has a nice spacer. btw, it also helped out his braking on his 97, spring from arm to proportioning valve for rear brakes was at too much of an angle.
87,33`s,6-1 t-case,d.c.drive shafts,locked,m/l with cj`s,dt8000`s,& the will to BEAT THE SNOT OUT OF IT!
