Gears
  • 15 Replies
  • 4308 Views
Offline fullsink18
  • 250
  • Wheel Me!
Gears
« on: July 26, 2006, 06:18:43 AM »
I am having a hell of a time understanding all the gear ratios. (Sorry, used to cars with only tranny gears).  So let me ask some question and see if I can get my self straightned out.
1. What is the stock gear ratios of manual trans 94 kick?  Front diff, Transfer Case, Rear Diff
2. What is 10 bolt vs. 12 bolt? Which do I have?
3. If I add bigger tires what gears should I change?
4.What gear ratios are available for manual kick?
5. If I add lockers does this effect what gears are in my kick?
5. Anything else I should know?
I really appreciate anybody taking time to help me out.  I have learned alot from this site.
94 2dr kick 8v
-     Full set of Calmini's skid plates, calmini header and full exhaust, k&n filter, sky idler arm, calmini idler arm brace and truss with stabalizer, lock-rite rear locker, Calmini 3"  BL, 2" Digger Spacers, Shrockworks bumper, chicago electric 8,000lb winch, 31" Grabber AT2, 15x7 2
Re: Gears
« Reply #1 on: July 26, 2006, 06:43:43 AM »
   Here's a link to a listing of what gear ratios where in what models of Trackers/Kicks from the Zuwharrie site.
http://bbs.zuwharrie.com/content/topic,15579.0.html
Offline fullsink18
  • 250
  • Wheel Me!
Re: Gears
« Reply #2 on: July 26, 2006, 08:17:41 AM »
Ok so 5.12 is most likely my stock gear ratio.  Is this for the front or back diff or the transfer case.
94 2dr kick 8v
Re: Gears
« Reply #3 on: July 26, 2006, 08:19:01 AM »
  front & back dif.  You shouldn't need to change any gears to run a tire up to around 31", maybe larger.  A locker does not effect your gears.
« Last Edit: July 26, 2006, 08:25:49 AM by LilRed »
Offline fullsink18
  • 250
  • Wheel Me!
Re: Gears
« Reply #4 on: July 26, 2006, 08:22:51 AM »
Alright, thanks that is one cloudy area that finally has some sun.  Now on to the transfer case.
EDIT: Found this:
Transmission     = 5 Speed Manual
Transfer Case    = Stock (Tracker T-Case HIGH Range = 1:1)
Ring and Pinion  = 5.12 (Stock Gears for 5 Speed Manual Trans)
So what is the 4 low range ratio?
« Last Edit: July 26, 2006, 08:25:28 AM by fullsink18 »
94 2dr kick 8v
Offline locjaw
  • 2045
  • 22
Re: Gears
« Reply #5 on: July 26, 2006, 08:25:50 AM »
the transfer case , in high range, is 1:1 straight thru. in low range it is (i beleive) is like 1.816:1
good luck
jason
Offline fullsink18
  • 250
  • Wheel Me!
Re: Gears
« Reply #6 on: July 26, 2006, 08:32:47 AM »
I should have read a bit farther instead of getting excited. I found the following:
Tracker 5 Speed Manual Transmission /T ransfer Case / Ring & Pinion Gearing Ratios
Gear ratios
   1st 3.65
   2nd 1.95
   3rd 1.38
   4th 1.00
   5th 0.86
   Reverse 3.67
Transfer gear ratios
   Low (4WD) 1.82
   High 1.00
Differential ratio 5.12
Question 1 is checked off.
As for Question 3 I think I should change my R&P to 5.83 for the 31 inch tires.  Right?
As for the rest of the questions keep the info coming.  Thanks
94 2dr kick 8v
Offline kirknd4spd
  • 333
Re: Gears
« Reply #7 on: July 26, 2006, 10:47:13 AM »
the 5.12s should handle 31" tires, but it cant hurt to switch to 5.83s
Offline Jookycola
  • 372
Re: Gears
« Reply #8 on: July 26, 2006, 11:04:36 AM »
Yeah, i STILL don't know what the heck a 10-bolt and 12-bolt is???
or how you find out?
and i've been driving these things for almost 20 years.
weird.
  [/url]
Offline fullsink18
  • 250
  • Wheel Me!
Re: Gears
« Reply #9 on: July 26, 2006, 11:18:53 AM »
Well I wont be getting 5.83s and time soon so 5.12 will have to handle the 31s.
LOL
If I could figure out what I have that would be good to know.
Calmini's Site has this listed for their R&P Gears.
10 Bolt '89-'98 Front
12 Bolt '93-'98 Rear (discontinued)
So maybe I have a 10 bolt up front and a 12 bolt in the rear???
But there 12 bolt R&P is discontinued, so I need to find somewhere else to get those.  If indeed I have a 12 bolt.
To double check I can put the same locker in my kick with 5.12s or 5.83?
Question 1: Check
Question 3: Check
94 2dr kick 8v
Re: Gears
« Reply #10 on: July 26, 2006, 01:07:24 PM »
weird.
10-bolt/12 bolt refers to the number of bolts that hold the ring gear into the diffcarrier.
Offline Quaddawg
  • 1622
    • My Ebay Store
Re: Gears
« Reply #11 on: July 27, 2006, 05:40:49 AM »
weird.
Yeah, and the poster has 12 bolt in the rear, and they AREN'T available.    Boondocks is/was going to order some.. but they haven't yet.
Good luck finding them.
My Kick was a DOG with heavy 31" tires and 5.12's  but others say different things.... I found a set of 5.62's by chance, and that made it quite a bit better.
Offline fullsink18
  • 250
  • Wheel Me!
Re: Gears
« Reply #12 on: July 27, 2006, 05:56:40 AM »
Question 1: Check
Question 2: Check
Question 3: Check
Good News:
I starting to feel pretty smart on the subject.
Bad News:
Darn that figures the gears I need happen to be the hardest to find.
I assume that I have a 10 bolt front member.  But changing those gears only helps in 4 wd.
94 2dr kick 8v
Re: Gears
« Reply #13 on: July 27, 2006, 06:16:17 AM »
No
« Last Edit: July 27, 2006, 06:17:59 AM by LilRed »
Offline fullsink18
  • 250
  • Wheel Me!
Re: Gears
« Reply #14 on: July 27, 2006, 06:28:54 AM »
Question 1: Check
Question 2: Check
Question 3: Check
Question 4: Check
Question 5: Check
Well I am pretty good to go now.  As soon as I get some money saved up I will put my name on boondocks waiting list for the 5.83 R&P.
Thanks a ton to a great group of intelligent people.
94 2dr kick 8v
