1.6 16v samurai swap wiring need help
  • 2732 Views
Offline superzooki198806
« on: July 30, 2006, 09:55:11 AM »
i need help trying to get the wiring on my zooki
like with the distributor can any one help
Re: 1.6 16v samurai swap wiring need help
« Reply #1 on: July 30, 2006, 01:34:18 PM »
There are a couple of different distributors. What does yours look like? how many wires? does it have the coil integrated with the distributor?
« Reply #2 on: August 01, 2006, 10:50:48 AM »
I've PM'd you but I'll reproduce the info here so it is available to all. On the 3 pin dizzy the white wire is from the ECU, the black/blue is the switched 12V supply from the main relay and the black/green is the ground. I have a 3pin dizzy here, if it is the same as yours can you tell me which wire goes to which pin
Thanks
James
« Reply #3 on: August 05, 2006, 07:53:46 PM »
the white is on the end blue is in the middle and black is on the left
« Reply #4 on: August 06, 2006, 06:09:05 AM »
Thank you, thats a big help to me.
