Quick Question
  • 2059 Views
Offline supermanwv
  • 38
Quick Question
« on: July 31, 2006, 11:36:35 AM »
Something I noticed while driving this Samurai home after I bought it was.....no matter how long it runs...when I move the heater setting to hot, it still blows cold air out the front vents.  I didn't try to blow it out the defrost vents or floor vents, but would that make any difference.  What would cause that?
Clark
Offline madbob
  • 33
Re: Quick Question
« Reply #1 on: July 31, 2006, 12:18:36 PM »
possible.....
the heater core under the dash went bad.  then the P.O. unhooked the water lines and looped them back to the block.
I did that to a datsun in high school, cuz it kept dumping antifreeze in the passenger floorboard.
Offline Yoak
  • 577
Re: Quick Question
« Reply #2 on: July 31, 2006, 08:18:14 PM »
I would check the hoses...if nothing is getting there....well then there won't be heat :)
Offline mss94jx
  • 8
Re: Quick Question
« Reply #3 on: August 01, 2006, 03:30:37 AM »
it could be really low on coolant. check that first.
Re: Quick Question
« Reply #4 on: August 01, 2006, 04:57:50 AM »
Blocked up heater is very common. Somewhere on the web is an article showing how to cut a hole in the side of the heater housing to get a vacuum in there. Easier than removing the whole heater assembly
Offline supermanwv
  • 38
Re: Quick Question
« Reply #5 on: August 01, 2006, 11:28:21 AM »
These water hoses that feed into the heater....where do they come off of on the motor?  Should I be able to see them easily from the engine compartment, or do I need to crawl under the vehicle?
I am going to check and see if the P.O. did loop them back to the engine rather than running them through the heater.
Clark
Offline da_tub
  • 307
Re: Quick Question
« Reply #6 on: August 01, 2006, 01:11:51 PM »
passengerside and they''ll head to the firewall,,should be two nipples sticking out one for each hose... real easy to find
91 four door ,and some stuff
