kick
  • 19 Replies
  • 4832 Views
Offline fordi64x4
  • 9
Re: kick
« Reply #15 on: August 02, 2006, 04:58:53 PM »
when i say the intake i mean the part coming off the throttle body going to the airbox, and the tester measures volts, battery= 12, when charging= 14 and so on, if you put it between positive post and cable it will measure draw but the tester was also arcing on the thermostat housing as well so i think its the whole block, and the spacer is conductive but im not sure
Offline da_tub
  • 307
Re: kick
« Reply #16 on: August 02, 2006, 11:53:57 PM »
id have to go with a bad ground man,, check there... like they say a bad ground will get you every time...good luck i hate electical work...lol
91 four door ,and some stuff
Re: kick
« Reply #17 on: August 03, 2006, 05:03:59 AM »
I think I'm with you now it just the terminology. Voltage = drop, Current = draw. That intake tube is bolted hard to the engine so it should be at the same potential as the block. Most modern electronics should be protected against reverse battery connection, I know that the ECU is pretty well protected so I doubt if you will have a problem there.
Offline TysonS
  • 383
  • www.funinbc.com
Re: kick
« Reply #18 on: August 03, 2006, 10:18:37 AM »
just to let you know, dropped in a new alternator and it ran like a charm untill the clutch cable came off that clip by the air box and melted on the heatsheild  :'(
Re: kick
« Reply #19 on: August 03, 2006, 12:11:25 PM »
Thats good that your sorted it. My clutch cable came unclipped once, went into the fan. Made a terrible noise but no real damage done.
