Samurai steering? X-over vs. hi-steer
  • 2750 Views
Offline zukmon
  • 94
« on: August 03, 2006, 03:47:04 AM »
Is one better for a Samurai with about 10 inches of lift(no body)? I like the SpiderTrax cross over because it does not reqire 2.5" backspaced wheels or spacers like all the hi-steer kits. What ever happened to the Calmini daul cross over?  That set-up looked trick, plus adjustable.
Re: Samurai steering? X-over vs. hi-steer
« Reply #1 on: August 03, 2006, 11:44:58 AM »
give sky a call, his even has fj-80 tre's if you want just send him your pitman arm and like twenty bucks to bore it out a little for ya, thats the one i'm saving up for.
Offline kirknd4spd
  • 333
« Reply #2 on: August 04, 2006, 12:37:11 AM »
in my opinion, crossover steering systems work better than hi-steer
Offline DaddyDave
  • 204
  • Indeed
« Reply #3 on: August 04, 2006, 04:06:59 PM »
Please elaborate...
Offline kirknd4spd
  • 333
« Reply #4 on: August 04, 2006, 06:13:42 PM »
one of my friends had a hi-steer system on his jeep, and he only had trouble with it.  since he put on a crossover system, he hasnt had any problems.
Offline zutefisk
  • 124
  • yumpin yiminy yee viss
« Reply #5 on: August 05, 2006, 01:04:24 AM »
High steer moves your tie rod up out of the rocks.
If you are just trying to fix your steering, Drop pitman, cross over, and hi steer all help eliminate/mitigate bump steer the same way, they move the steering arm back closer to parallel with the axle and let you get rid of the z-link.
I've got breeze cross over with 3.5 back spaced wheels, no issues. Might add a drop pitman someday but ...
87 Samurai
