4 door GV springs
  • 2358 Views
Offline bus_driver
  • 479
  • the voices tell me different things
4 door GV springs
« on: August 03, 2006, 11:41:58 PM »
in the budget lift the 4 dr track was lifted with GV springs all round .... has anyone done the GV springs on a 2 dr track like my 92.... and if so how much lift was gained??? if I could find a set of rears I would thro them on my guy and use spacers on the front to match the rear and I would be really happy.
are the spring a heavier rate or longer??
92 2dr soft top
2-1/4" cherry bomb exhaust
235/75/15
2 inch lift
custom mud
Offline kirknd4spd
  • 333
Re: 4 door GV springs
« Reply #1 on: August 04, 2006, 12:28:50 AM »
the GV springs should lift the 2 door the same amount as the 4 door, but im not 100% sure
Offline bus_driver
  • 479
« Reply #2 on: August 06, 2006, 10:00:25 PM »
iwas thinking the weight between a 2dr soft top and a 4 dr tin would be a bit differnet yeilding a higher lift. and maybe a harsher ride.
92 2dr soft top
235/75/15
2 inch lift
custom mud
« Reply #3 on: August 07, 2006, 04:58:55 AM »
I think you are right, I'm pretty sure the 4dr has stiffer rear springs.
Offline bus_driver
  • 479
« Reply #4 on: August 07, 2006, 11:10:24 PM »
does anybody have access too specs of stock springs and would be able to find out the rates between my stock dr and the 4 drs rear springs ????
cuz if it turned out to go like 2 1/4 that would be cool and then do the spacers on front  that would make for a really nice trail machine. and look the shit too
92 2dr soft top
235/75/15
2 inch lift
custom mud
