samurai front axle help!
samuraijones
19
i love my samurai
August 05, 2006, 09:06:46 PM »
i posted a topic the other day (bronken frot axle?) and a couple a guys told me it was a axle but when i lifted my front end (to find out which side the broken one was on) and locked the hubs then turned the tire they both spun freely. is this not the proper way to check for that or is the problem in the hubs or diff. 2 busted axles!!??
wildgoody
8134
67
Re: samurai front axle help!
August 05, 2006, 11:04:13 PM »
some axles break but still can turn
the drive shaft, you need to take the
whole axle apart to check both axles
as well as the birfields, axles tend to
break near the diff, so you need to
pull that too, and both axles need to
be out to do that
john1974
617
http://zuknation.net
August 06, 2006, 07:33:17 AM »
ya its possible for it to still turn, I would just starting taking it apart check the axle u think is bad first might save ya some time.
John
*Image Removed* [/URL] *Image Removed* [/URL]
samuraijones
19
i love my samurai
Reply #3 on:
August 06, 2006, 01:15:10 PM »
niether tire will turn the drive shaft
Rhinoman
4502
36
Bend it, Break it, Fix it
Reply #4 on:
August 06, 2006, 01:19:16 PM »
Quote from: samuraijones on August 06, 2006, 01:15:10 PM
The diff might be confusing things. Try turning the driveshaft and seeing if the wheels turn. Also drain the oil and check for metal.
http://www.rhinopower.org
