RIMS
  • 2897 Views
Offline MUDDING4LIFE
  • 8
RIMS
« on: August 06, 2006, 12:47:48 PM »
WHAT KIND OF RIMS ARE INTERCHANGEBLE WITH MY 1987 SAMI????????/
Offline Uncivilized
  • 1469
    • Car Domain
Re: RIMS
« Reply #1 on: August 06, 2006, 01:47:49 PM »
Go to this site, and look for anything that says 5x5.5"(139.7mm)
http://www.discountedwheelwarehouse.com/Vehicle_Bolt_Pattern_Reference.cfm
All Suzuki Sidekick, vitara, grand vitara
Ford Bronco 66+; F1/2 TON F-100,150 TRUCK 54-95; 1/2 TON E-100,150 VAN 70-96
Dodge Ramcharger 79-83; RAM 1/2 TON TRUCK 2 & 4WD 94+; RAM VAN 85-96; etc, etc.
Jeep CJ wheels(15x7) are a nice choice, as well as the old Bronco rims(15x7/8)
Offline strvger
  • 95
  • Livin' on the edge... of the Great Northwoods !!
Re: RIMS
« Reply #2 on: August 06, 2006, 06:15:21 PM »
hi,
any of the OLDER Dodge/Jeep/Scout rims will work.  with these older rims you can sometimes find the 16 inch wheels with the same 5x5.5 pattern and large center openings.
 Ford rims have the same bolt pattern, but the center opening is smaller!  it won't fit without widening the centers.
'91 tracker, 1.6 8v 5-spd, 1.5 in susp lift,  DT header and 2 in exhaust, 235/75 AT's on 15x7 Turbines, 1st prototype: Ibuiltbumpers.com trackick front bumper!,  other mods coming soon!
Offline Uncivilized
  • 1469
    • Car Domain
Re: RIMS
« Reply #3 on: August 06, 2006, 06:32:26 PM »
I'm pretty sure that's only if the rim is from a 2wd Ford, the 4wd Fords should be okay.
Offline strvger
  • 95
Re: RIMS
« Reply #4 on: August 06, 2006, 07:00:10 PM »
i think you'll find that the older 4X4 Fords had those narrow little axle ends with those little manual hubs sticking out.  that's why the centers were smaller diameter than the other makes of the same time period.
