BEST RUST FIGHTER
  • 16 Replies
  • 5323 Views
Offline MUDDING4LIFE
  • 8
BEST RUST FIGHTER
« on: August 06, 2006, 12:49:27 PM »
WHAT IS THE BEST RUST FIGHTER I CAN USE ON MY SAMI TO LAST????
Offline Uncivilized
  • 1469
    • Car Domain
Re: BEST RUST FIGHTER
« Reply #1 on: August 06, 2006, 01:36:08 PM »
POR-15
http://www.por15.com/
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
« Reply #2 on: August 06, 2006, 04:31:34 PM »
I sanded down some bubble rust I had, then coated it with some stuff called rust converter from wall mart.  Works well no rust has returned where I used it.  there some other stuff out there that works well too, like post aboved mentioned, some of that junk out there is useless tho.
get something that everyone says they have used...
Offline ddevil
  • 155
« Reply #3 on: August 06, 2006, 05:22:20 PM »
i had some slight surface rust on my tracker(inside under the dash kinda by the door hinge but back further on both sides, actually just about under the fuse box kinda on the driver side) i just sanded it down a good bit and clearcoated it, for now at least...
mike
'95 geo tracker 2dr 5spd soft top with 2" suspension lift
Offline Carnage
  • 2453
« Reply #4 on: August 06, 2006, 05:24:02 PM »
what about those electric rust preventers?
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #5 on: August 06, 2006, 06:07:10 PM »
They sound interesting, I've only heard about them from friends but have no idea how they work, it would be nice to know though
Offline daddyizzle
  • 728
  • Colorado is still my home!!
« Reply #6 on: August 07, 2006, 06:27:19 AM »
Ihe key ingredient in rust convertor is  phosphoric acid. You can buy a gallon for around 12.oo bucks at a chemical supply store and mix it with 4 parts water. It will kill the rust in one or two treatments. depending on how bad, it may not take care of it if it is more than surface rust.  The advantage to the convertors is that they often times have other chemicals that provide a prime. If the project is large, like a 600 ft. 5 1/2 inch steel pipe fence that I painted, it would be almost cost prohibitive to use a convertor. In your case, I would use the convertor. I see it at Lowes, and commercail paint stores. I always keep a qt. on hand. I have heard that it causes certain undercoatings and bedliner spray to peel. Not sure if its true but someone here probably has experience in that area. Adam
Offline Quaddawg
  • 1622
    • My Ebay Store
« Reply #7 on: August 07, 2006, 06:52:44 AM »
I personally think "Chassis Saver"   from Magnetic Paints company beats POR-15
BUT, POR-15 is good too.
I used Chassis Saver on my little rust bucket about 7 months ago, and no where that I painted is rusting yet, and my bucket was DEFINITELY rusted..  (still is in many places)
Offline keith
  • 1176
« Reply #8 on: August 07, 2006, 06:53:17 AM »
With POR-15 or Chassis Saver do you have to sand the paint off of the surface first?  Here is a pic of the kind of rust I'm looking to use it on.  http://www.keithert.com/pics/nx2000/DSCF5919.JPG
« Last Edit: August 07, 2006, 07:01:59 AM by keith »
  • 6603
  • 69
« Reply #9 on: August 07, 2006, 09:57:58 AM »
Rust-Ease Medicated Bumper Ointment...
Offline da_tub
  • 307
« Reply #10 on: August 07, 2006, 10:25:56 AM »
por 15 is great stuff and all. butt the thing with this product is unless you want it black, no paint will stick to it...
91 four door ,and some stuff
Offline Frank84
  • 176
« Reply #11 on: August 07, 2006, 12:38:45 PM »
http://www.por15.com/PRODUCTS/PRIMERPAINTSCOATINGS/PRIMERS/TIECOATPRIMER/tabid/130/Default.aspx
expensive, but you can paint over cured por-15
ordered some por-15 for use on a '62 impala - going to try the stuff out this week
2001 2 Door Tracker, 4x4, 2.0, 5 speed, 215/75/15
Jeff's 2" lift, OME shocks/struts, Sh*t on the fly removed, warn hubs
Offline Quaddawg
  • 1622
    • My Ebay Store
« Reply #12 on: August 07, 2006, 01:02:38 PM »
chassis saver is an EXCELLENT primer..
Keith, you are going to have to chip all that bubble rust away, and then apply a POR15 or CHASSIS SAVER type product, then skim with body filler, and reprime and then paint.
That is an easy spot to fix..
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #13 on: August 07, 2006, 01:58:02 PM »
I don't think you need POR15 for that, if it were me, I'd remove the fender and bottom a-pillar trim, then sand/grind it to bare metal - if it's bumpy I'd fill it with a little short-strand fiberglass(or body-filler will do) sand it smooth, and prime it. Then, go to my local CarQuest shop with the color code of the car and have a spray-can made of that color, and paint it. That's not a bad area to have rust, I bet if you did this, it wouldn't creap out for a few years, if at all.
« Last Edit: August 07, 2006, 01:59:58 PM by Uncivilized »
Offline Quaddawg
  • 1622
    • My Ebay Store
« Reply #14 on: August 07, 2006, 03:53:51 PM »
true.. BUT, if you used a little chassis save on it.. I don't think it would EVER creep out again.
That stuff STOPS rust dead.
