pinion seal replacement question NEED HELP PLEASE
  • 1829 Views
Offline lifted4runner
  • 8
« on: August 06, 2006, 01:05:21 PM »
I have tracker 4.62s in my samurai and was wondering what the torque specs are on the pinion nut. also, what do I need to properly replace the seal? IE: new nut, bearing.  Thanks
« Last Edit: August 07, 2006, 05:02:45 PM by lifted4runner »
1986 Tintop JX
Trail-Tough hybrids w/ 463's
TT double tough front axles
Locked front and rear
Cj springs all around SPOA Rocky Road Missing Links front and Rear DT Pre-Runner 8000's Spidertrax wheel spacers 33" Boggers Custom Rhino lined exterior Custom PVC snorkel 2.5" exhaust Pony carb
Offline zutefisk
  • 124
  • yumpin yiminy yee viss
Re: pinion seal replacement question NEED HELP PLEASE
« Reply #1 on: August 07, 2006, 11:44:37 PM »
I had same question. Only got part of the answer
You'll want a nut and crush sleeve. (or maybe two crush sleeves). I used the samurai torques.
torque wrench that reads inch pounds can be real pricey, local bicycle shops have them.
87 Samurai
« Reply #2 on: August 08, 2006, 09:48:57 AM »
Go to http://www.suzukiinfo.com and download the FSM for the SJ416Q. Setting up the diff is fairly complicated if you've not done it before, you really need to refer to the charts that are given in the manual. I don't think its really something that can be adequately described here.
