5.62 Gears?
  • 2136 Views
Offline fullsink18
  • 250
  • Wheel Me!
5.62 Gears?
« on: August 07, 2006, 01:18:38 PM »
I found an offer for a 3rd member with 5.62 gears in it.  The seller said that this is from a stock sidekick.
Did the sidekicks ever come with 5.62 gears or did he count wrong?
I just put on some 31s so these gears would be a little better than 5.12s
« Last Edit: August 07, 2006, 01:25:53 PM by fullsink18 »
94 2dr kick 8v
-     Full set of Calmini's skid plates, calmini header and full exhaust, k&n filter, sky idler arm, calmini idler arm brace and truss with stabalizer, lock-rite rear locker, Calmini 3"  BL, 2" Digger Spacers, Shrockworks bumper, chicago electric 8,000lb winch, 31" Grabber AT2, 15x7 2
Re: 5.62 Gears?
« Reply #1 on: August 07, 2006, 01:25:04 PM »
Yes they did. The 89 model Sidekick with the 1.3L motor had the 5.62 gears.
Offline fullsink18
  • 250
  • Wheel Me!
Re: 5.62 Gears?
« Reply #2 on: August 07, 2006, 01:26:02 PM »
Would I have to find the same gears for the front or would be ok to run the stock gears up front and 5.62s in the rear
94 2dr kick 8v
Offline Uncivilized
  • 1469
    • Car Domain
Re: 5.62 Gears?
« Reply #3 on: August 07, 2006, 01:32:56 PM »
It's fine as long as you don't ever plan to use 4wd  :'(  You'll need to find a front set, however the 5:62, as well as the 5:38's are extremley rare, and you'll have a hard time finding them.
