Bump Stop Extensions
  • 1370 Views
Offline bzzr2
  • 1011
« on: August 11, 2006, 11:36:24 AM »
What is everybody doing for bump stop extensions on trackers/vits/kicks?  I should really do this when I add the extra inch in back..  this should help with my tire rub issue.  any input or suggestions would be appreciated, thanks!
09 taco reg cab short box 4x4
Offline AJMBLAZER
  • 2166
  • Your mom.
Re: Bump Stop Extensions
« Reply #1 on: August 11, 2006, 03:27:58 PM »
Cheap, easy, and small is just a short 1/4" spacer or so that goes on like a big washer.  However that's about as much as you can get out of them.
A bit more expensive would be to get some of Energy Suspension's stepped bump stops and run those.  I have some on my Ranger, cost about $40 or so.  You'd just need to find a bolt with the same thread as the threaded shaft of the OEM bumpstop.  If you needed some more length just space them down some with stacks of large washers or something similar and use a longer bolt.
