Front fenders removed? Anybody
  • 2390 Views
Offline 96Kicker
  • 1043
  • http://www.zukiworld.com/forum/gallery/3710_25_10_
    • www.myspace.com
« on: August 12, 2006, 11:09:13 AM »
I am thinking of removing my front fenders on my tracker and would like to see if anyone has done this and have pics.
Sooner or later my rig won't even be street leagal.  I like to wheel the crap out of it and thought of removing them instead of smashing them up or cutting them.
Any thoughts on this or pics would be great.
<a href="http://s220.photobucket.com/albums/dd126/fletcher9160/?action=view&current=Zuktahgreenblur.jpg" target="_blank"><img src="http://i220.photobucket.com/albums/dd126/fletcher9160/Zuktahgreenblur.jpg" border="0" alt="Zuktah club sticker"></a>TJ
#801-554-3281
96 kick 4 door with custom 3 inch susp lift and pre runner front bumper,2 inch bod
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: Front fenders removed? Anybody
« Reply #1 on: August 12, 2006, 12:00:53 PM »
The 10mm bolts run around the front, top, door-side and rocker-panel edge of the fender.
The toughest to get to is the one on the top end of the door jamb (under the trim plate in front of the sideview mirror) and the two at the bottom. The two bottom bolts are exposed to a lot of water/dirt and are hiding under the plastic rocker panel trim.  You'll need to carefully examine how the trim piece is attached before removing it.  The two bolts should be soaked with PB Blaster to guarantee that you don't break the bolts as you remove them.
Take a peek at an aftermarket manual for your Tracker at the local public library (Chilton is better than Haynes) for more info.
Don't forget to disconnect the side marker lamp circuit!
If the fenders are in good shape and you didn't bugger them, you might be able to sell them!
Ack
Offline MAA
  • 16
« Reply #2 on: October 31, 2006, 05:25:36 PM »
2"BL, no Suspension lift YET, no rubbing
Offline mntracker
  • 314
  • MORNEAU MVP
« Reply #3 on: October 31, 2006, 05:29:27 PM »
I had my drivers side one off and a replacement back on in less than an hour. When I bought my Tracker, there was a 2 foot piece of primer on it, and found a color matched replacement for $60.
Offline flea
  • 117
    • kczuks.US
« Reply #4 on: November 06, 2006, 12:26:09 PM »
 >:D >:D
Offline WorkInProgress91
  • 31 gets it done
« Reply #5 on: November 06, 2006, 02:58:06 PM »
I like the tube work!  I was thinking about building some flat fenders for the front, anyone ever seen these on a sidekick?  hopefully with the fenders out of the way, and the hagen widening mod i'll be able to stuff some 33's under my rig
91 sidekick
2'' B/L, 2'' coil spacers
31'' swampers
winch
custom bumper tank lift camouflage duct tape
