What all is Needed to Change my 8v to a 16v engine?
  • 3 Replies
  • 1573 Views
Offline Jimiweld
  • 234
    • www.fullfusion.ca
« on: August 12, 2006, 06:17:22 PM »
What all will I need to do this in my tracker. I will need the computer, but will I need the wiring harness, rad, hoses etc as well? Or do all of these just plug into the 8 valve?
Jim
1990 Tracker - 3.5" body Lift, 1.5 coil spacers, 31" TRXUS tires, homemade front bumper, Automatic Tansmission, 5.12 diff gears. Rear is Locked
Offline CJ11
  • 157
  • 95 SIDEKICK ON 31'S
Re: What all is Needed to Change my 8v to a 16v engine?
« Reply #1 on: August 12, 2006, 10:58:15 PM »
What you need to do is find a 16V kick in good shape and swap the bulk of your good parts on it.. That will be the easiest way to go.
Offline Jimiweld
  • 234
    • www.fullfusion.ca
« Reply #2 on: August 13, 2006, 06:09:15 AM »
Really, that much work then eh. I'll probably just replace mine with another 8v when it dies then. It's ok for now, but if a 16v was an easy swap I thought I'd start looking for the bits and pieces now to prepare for it.
Offline wezzlegod
  • 227
  • under construction crowler
« Reply #3 on: August 13, 2006, 09:23:28 AM »
you have to replace the computer wire harness for the moter it should clip into your truck existing routing  and spliceing points. and moter with all the exesories(m.a.f.air intake ect). go to the action and get a wrecked one. its not that diffacult of swap a few weekends about 10 hours.
black 89 sidekick toyota 22re L52 5speed trans w/ duel t cases. toyota axles w/coil springs 4 link double triangle 3 link front, 5.29 r&p, lockers ,35x12.5 tires, rock rails ,custom plate steal bumpers, killer xm sounds ext ext ext
