Engine problem on my tow vehicle
CJ11
157
95 SIDEKICK ON 31'S
August 13, 2006, 12:16:24 PM »
Not suzuki related but the vehicle I will use to tow my kick to the trail has a little problem. It is a chevy tracker (conversion van) 1993.when I give it gas it just sputters and will bareley getup to 30mph. Sounds slightly better when it is in park and I rev it but not much better. Up hill it even slower. Idle is fine cant tell anything is wrong. Anyone have any ideas. Where should I start. Tanks for any help in advanced. I know my suzukis in and out but not the chevrolet............
wezzlegod
227
under construction crowler
Re: Engine problem on my tow vehicle
August 13, 2006, 04:06:24 PM »
sounds like a fuel problem or a cloged cat. or tps(throttle position sensor) or maf(mass airflow sensor). no check engine light?
? check your codes. it should point you in the right derection.
wildgoody
8134
67
August 13, 2006, 06:53:39 PM »
Bad MAP will do this too, make sure the vacuum
line is attached to it , mine came off, was driving
me crazy, replaced the fuel filter and it didn't help,
cost me $25 for the filter
