sammy winch
  • 10 Replies
  • 2898 Views
Offline SKAsammy
  • 79
  • 1991 samurai
sammy winch
« on: August 16, 2006, 04:18:35 PM »
so many to choose from, which winch should i get?
1991 SAMURAI
6"spoa
2" body  lift
8000 lb winch
30/9.5/15 BFG all terrains roll on bedliner in and out homemade bumper 1996 Silv. 4" lift 35's many mods
Re: sammy winch
« Reply #1 on: August 16, 2006, 04:50:54 PM »
If you keep a sammie light you don't really need one, I have a warn 6k on mine and have never used it, use a block and it is a 12k, it's nice and light and does not bother the radiator as far as cooling goes and as far as current drain goes it draws way less than a 9k does,just get a yellow top battery and go.
Offline SKAsammy
  • 79
  • 1991 samurai
Re: sammy winch
« Reply #2 on: August 16, 2006, 07:02:35 PM »
Thanks, my sammy was up to the windows in mud the other day...i dont have the pictures yet but ill get em... let me explain.  They drained a lake right outside of town and for the most part it is dried out.  But the weeds have completely filled where the lake was.  We wheeled in the lake for probably 2 hours without a problem then all of a sudden under we went, it was kinda freeky sinking that fast I thought my sammy was done for.  I had 3 big trucks get stuck trying to pull me out.  Not to mention the tow truck that got stuck after he got me out.  Anyways I figured with the $200 tow bill its probably time to just fork over the money and get a winch...Also is there a way to mount a winch without an aftermarket bumper and without removing the stock bumper? Thanks
1991 SAMURAI
6"spoa
2" body  lift
8000 lb winch
Re: sammy winch
« Reply #3 on: August 16, 2006, 07:53:39 PM »
I picked up a set of bushings from trail tough that weld inside the front of the frame x4 you will need these, I cut down a push bar style from a chevy s-10 made by warn, cut the tray about 1.5" and the head light guards about 2'' it fits great and the whole guard and winch weight in at 115 lbs, the stock bumper would have to go or cut the center section of it out and weld to the push bar.
Offline 88Sammy
  • 68
    • JDM parts
Re: sammy winch
« Reply #4 on: August 17, 2006, 04:19:38 PM »
I was looking at the Warn M8000 and M6000.
What about the 9.0Rc or 9.5xp winches?  Is that over kill?
Re: sammy winch
« Reply #5 on: August 17, 2006, 10:26:58 PM »
I have a Superwinch 9000 on mine and love it.  It's great when you need to winch a full size up a hill or pull a 1-ton with flat tires onto a trailer.  :)  The 9.5xp is a great winch, but if you only plan on using it once or twice a year, it's not going to be much better then the MileMarker 8000 electric.
If your looking for a light duty winch to pull you out of a small hole now and then, I think size and weight is going to be your largest issue.
Offline kymike
  • 87
Re: sammy winch
« Reply #6 on: August 18, 2006, 07:34:03 PM »
go to harbor freight the have a off brand 8000lb for 299 they work well esp on a sami i have a few friends that have been running them on jeeps for a few years now and still going strong
Offline madbob
  • 33
Re: sammy winch
« Reply #7 on: August 19, 2006, 06:41:59 AM »
if you get the code off there website, I think you can get that winch for 250.
Offline uglytrk
  • 51
    • trail krawlers 4x4
Re: sammy winch
« Reply #8 on: August 20, 2006, 07:23:56 AM »
I have the warn m6000 on mine works great for helping others. Zuks dont get stuck. The pulling power is there,but the poor little truck doesnt weigh enough to stay put. Allways seem to need a anchor.
87 Samurai spoa/shackle reverse in front w/ toy rear springs5.43w/detroit quick lock yj 5 leaf pack rear 5.43 w/ detroit quick lock grs1 4:1 t-case w/ poly mount and rocky road mega arms warn m6000 optima red top 35/12.50 bfg mt`s on 15/8 aluminum wheels Hilift cb rock light cage in rear
Offline zukzilla1662
  • 90
Re: sammy winch
« Reply #9 on: August 20, 2006, 05:50:42 PM »
can you post more picks of your sammy it looks sweet
Offline uglytrk
  • 51
Re: sammy winch
« Reply #10 on: August 21, 2006, 06:16:40 AM »
To keep from hijacking this thread, I`ll post my junk in the adventure forum.
