What does this small computer thing do?
  • 22 Replies
  • 5493 Views
« on: August 23, 2006, 01:19:53 PM »
It sits in the corner of the dash, goes up in smoke when under water, and the vehicle seems to run fine without it.  Anyone here know what it does?
I have a similar one in my SJ that the mainboard is broken on, and I never did look up what it is used for...
Re: What does this small computer thing do?
« Reply #1 on: August 23, 2006, 05:34:11 PM »
Buzzer?
« Reply #2 on: August 23, 2006, 07:23:51 PM »
I think it is part of the AC.
« Reply #3 on: August 25, 2006, 12:25:27 AM »
You can see where it plugs in.  I take it normal Sammy's don't have this little grey box tucked underneath the glovebox?
« Reply #4 on: August 25, 2006, 07:51:40 AM »
Only if they had AC on them, at some point.
Offline darnold87
  • 351
  • 11
« Reply #5 on: August 25, 2006, 08:28:00 AM »
So its definitely part of the AC then??
If so, mine is coming out...!  ;)
~Davey
'94 Suzuki Sidekick JLX
'04 Lexus GX470
« Reply #6 on: August 25, 2006, 08:34:18 AM »
I'm pretty sure that is an AC component.
Offline Element
  • 1902
  • LillyKicker
« Reply #7 on: August 25, 2006, 09:01:00 AM »
I have the same thing in mine and it flopps around every once in awhile.... I don't think my sami has ever had ac
zUkTAH
U4WDA
« Reply #8 on: August 25, 2006, 09:59:40 AM »
Wiper Delay module?
« Reply #9 on: August 25, 2006, 10:17:25 AM »
I'm 99% sure it is part of the AC.
Wiper Delay module?
I know it isn't a WDM.
Maybe the wiring harness has been changed out at some point.  You don't have one of the following....the double crank pulley, an AC switch in the dash, any AC brackets on the engine, any AC components under the dash, AC condenser, AC condenser fan, AC lines under the hood, AC evaporator, etc?
« Reply #10 on: August 25, 2006, 10:50:31 AM »
A quick scan of a Sammy wiring diagram indicates that it is most likely to be an AC controller.
Offline SKAsammy
  • 79
  • 1991 samurai
« Reply #11 on: August 25, 2006, 05:11:21 PM »
I thought that was where my door ajar buzzer noise came from.  Maybe not...I dunno just my two cents...Im probly wrong
1991 SAMURAI
6"spoa
2" body  lift
8000 lb winch
30/9.5/15 BFG all terrains roll on bedliner in and out homemade bumper 1996 Silv. 4" lift 35's many mods
« Reply #12 on: August 25, 2006, 08:35:48 PM »
It is not a buzzer.  A buzzer is a small black box, about 2"x1"x1", and it actually says buzzer on it.  IIRC, there is a buzzer over in that area.  There is also a buzzer on the back of the instrument cluster.
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #13 on: August 25, 2006, 09:14:18 PM »
It is the Air Conditioner system controller.
Ack
« Reply #14 on: August 27, 2006, 01:29:01 AM »
Yea, the new owner looked it up.  Now I'm wondering what the chipset in the corner of my SJ-410 is though...
Time to find the wiring diagram I guess.  :D
