base timeing
  • 2097 Views
Offline sidekick101
  • 128
  • best site on the net
base timeing
« on: August 28, 2006, 09:11:07 PM »
i was reading a manual on how to reset it. theres the plug under the hood tha`t you are suposed to "short out" so that the cheeck engin light comes on. found what i thought was the plug(where is everyone elses. the one i tried is near the barreri on the passengery side) but no matter what 2 hols i tried otu of the 4 none seemed to work?!? and the bulb is in there because when i turn the car on it turns on liek it is suposed to. nay suggestions?
1993 sidekick JX, 2 dr, soft top, automatic,
Offline nascarmanic
  • 31
Re: base timeing
« Reply #1 on: August 29, 2006, 08:58:00 AM »
If you are trying to time car. There are two plugs in the same area. the one with the rubber cap on it is the one to retard timing. I think with the tab facing up the bottom left and bottom middle slots should retard timing. I dont think this will turn engine lite on ,or mabye it does (never looked)
Re: base timeing
« Reply #2 on: August 29, 2006, 09:56:34 AM »
My plug is a 6 pin and is located behind the (US) passenger side headlight, usually there is a mauve/yellow wire going to it. I forget the other colours. The pics below should help:
The six pin connector:
« Last Edit: August 29, 2006, 09:58:47 AM by Rhinoman »
Offline muskegtracker
  • 273
  • 10
  • Mr T
Re: base timeing
« Reply #3 on: August 29, 2006, 11:46:13 AM »
I've got 91 tracker and had a similar issue.  My uncle at the local college got me a print out.  It is the four wire plug just by the battery, I think one of the wires is black/grey stripe.  I'll check my paper work and get back to you.
91 Chevy Tracker
Offline 96Kicker
  • 1043
  • http://www.zukiworld.com/forum/gallery/3710_25_10_
    • www.myspace.com
Re: base timeing
« Reply #4 on: August 29, 2006, 12:32:34 PM »
I think the plug is white and the other is black ,use the white one and if you turn your key to on,not start,just on, your check engine light should flash a code 12 3 times. This is a way to check your trouble codes.
 I think you use the same one to time your engine too?
but ive been wrong before.
Tj
<a href="http://s220.photobucket.com/albums/dd126/fletcher9160/?action=view&current=Zuktahgreenblur.jpg" target="_blank"><img src="http://i220.photobucket.com/albums/dd126/fletcher9160/Zuktahgreenblur.jpg" border="0" alt="Zuktah club sticker"></a>TJ
#801-554-3281
96 kick 4 door with custom 3 inch susp lift and pre runner front bumper,2 inch bod
Re: base timeing
« Reply #5 on: August 29, 2006, 12:49:13 PM »
To fix the ignition timing short the bottom pins.
  • 273
  • 10
  • Mr T
Re: base timeing
« Reply #6 on: September 06, 2006, 11:06:55 AM »
I got a print out from a local college automotive computer system.  It is for 91 tracker.  Probably the same for many others:
  -Run engine until it reaches operating temp
  -shut off
  -jumper wire(short piece of wire stripped at both ends) between black and blue/red wire
   located in diagnostic four wire plug just infront of the battery, by the fusable links.
  -Insert jumper
  -Turn key to ignition for 5 sec
  -Start engine
  -Perform Timing check
  -Shut off and remove jumper.
91 Chevy Tracker
