just did the search
just did the search
bus_driver
479
the voices tell me different things
just did the search
August 29, 2006, 09:45:35 AM »
on my high idle problem........ when I start it sits a 2000 pm then when half way warm it is perfect at 900 rpm then when fully warm it is 1200rpm and if I have been driving and come to a stop it is 1000rpm and then slowly goes up to 1200 again....is this the wax pelllet thingy or what i was thinking is the coolant temp sensor on the engine.
I am goin to bypass the wax pellet....but I was also running a little lean will the pellet creat the since it is essentially an air leak.
thank again for any help on the matter.
92 2dr soft top
2-1/4" cherry bomb exhaust
235/75/15
2 inch lift
custom mud
nascarmanic
31
I Love ZUKIWORLD!
Re: just did the search
August 29, 2006, 09:54:15 AM »
HUH?
Rhinoman
4502
36
Bend it, Break it, Fix it
August 29, 2006, 10:05:26 AM »
You are referring to the air valve, it allows air from the airbox to bypass the throttle body when the engine is cold, you could try blocking off the pipe and seeing if it behaves when warm.
http://www.rhinopower.org
bus_driver
479
Reply #3 on:
August 30, 2006, 09:14:38 PM »
yes I am talking about the cold start idle control....it is a wax controlled choke is it not? if that wears out is it like having an air leak in the throttle body making the truck run lean and a little higher revving at idle.
92 2dr soft top
235/75/15
2 inch lift
custom mud
