Lock-Rite for Samurai front axle
  • 1895 Views
Offline Sammy N Austin
  • 16
« on: September 06, 2006, 02:51:48 PM »
I have been advised that a Lock-Rite Locker for the front axle of my otherwise stock 88 Samurai is the way to go. His reasoning is that in 2WD with the hubs unlocked it will have no effect on steering and will be quiet on the road. When the hubs are locked in4WD it would help pull the vehicle up and over obstacles.
What are the pros and cons of Lock-Rites front or rear or both?
I would love to install ARB Air Lockers front and rear, but they are prohibitively expensive.
« Last Edit: September 06, 2006, 02:53:38 PM by Sammy N Austin »
88.5 Samurai Soft Top
97 LX450
Re: Lock-Rite for Samurai front axle
« Reply #1 on: September 06, 2006, 04:34:00 PM »
   It will make it difficult to steer when in 4WD which would be amplified by larger tires.  I'd recommend you add power steering if you put a lockrite in the front.
Offline 89tintop
  • 356
« Reply #2 on: September 06, 2006, 04:46:15 PM »
and forget about street driving it in the winter, thats if you have snow where you are from.
91 kick 4 door 2 inch body lift, 2 inch spacer lift, 31's.
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
« Reply #3 on: September 06, 2006, 06:35:17 PM »
Ya my friend has one in the front of his sammy,  hard to turn when wheeling.  Tracker/Sidekick power steering conversion one of my friends did locked front and rear... real nice!!!
