2007 Suzuki GV Specs
  • 4039 Views
  • 6601
  • 68
« on: September 07, 2006, 08:31:22 AM »
2007 Suzuki Grand Vitara
ENGINE
Type:            2.7-liter, V6, 24-valve DOHC
Materials:         Aluminum cylinder block/aluminum cylinder heads
Displacement:         2.7 liters (2,736 cc/167 cu. in.)
Bore x stroke:         88.0 mm x 75.0 mm/3.46 in. x 2.95 in.
Compression ratio:      9.5:1
Horsepower:         185 hp |removethispart|@ 6,000 RPM
Torque:         184 lb.-ft. |removethispart|@ 4,500 RPM
Valves per cylinder:      Four
Fuel system:   Electronic multi-port fuel injection, variable induction system, in-tank fuel pump
Emission compliance:      LEV II/BIN5
Exhaust:         Single
TRANSMISSIONS
Five-speed manual
1st            4.550:1
2nd            2.357:1
3rd            1.695:1
4th            1.242:1
5th            1.000:1
Reverse         4.436:1
Final drive ratio      3.583:1
Five-speed automatic
1st            3.520:1
2nd            2.043:1
3rd            1.401:1
4th            1.000:1
5th            0.717:1
Reverse         3.224:1
Final drive ratio      4.300:1
FOUR-WHEEL-DRIVE SYSTEMS
Four-Mode full-time four-wheel drive:  all-wheel-drive system and two speed – transfer case with locking differential and low range gearing.  The operating modes are:  4H mode, 4H lock mode, 4L lock mode (differential is always locked in 4L) and neutral mode for flat towing.
SUSPENSION
Front:   Independent:  MacPherson strut suspension with coil springs, hydraulic shock absorbers and anti-roll bar.
Rear:   Independent:  Multi-link suspension with coil springs, hydraulic shock absorbers and anti-roll bar.
STEERING
Type:   Power-assisted rack-and-pinion
Overall ratio:   14.0:1
Turns, lock-to-lock:   2.7
Turning circle:   36.7 ft. (11.2 meters) curb-to-curb
BRAKES
Front:   Power-assisted vented disc with floating two-piston calipers and pad wear sensor
Rear:   Power-assisted rear drum (10.0 in./254 mm)
ABS:   Standard, four wheel, four channel
Traction control:      Standard
Electronic Stability
Program (ESP)1:      Standard
WHEELS         16 x 6.5-in. steel
            16 x 6.5-in. alloy
            17 x 6.5-in. alloy
TIRES            P225/70R16
            P225/65R17
Spare:            P225/70R16
EXTERIOR DIMENSIONS
Wheelbase:         103.9 in. (2,640 mm)
Overall length:         176.0 in. (4,470 mm)
Overall width:         71.3 in. (1,810 mm)
Overall height:         66.7 in. (1,695 mm) 4WD/66.3 in. (1,683 mm) 2WD
Tread width, f/r:      60.6 in. (1,540 mm)/61.4 in. (1,560 mm)
Overhang, front:      29.7 in. (755 mm)
Overhang, rear:      42.3 in. (1,075 mm)
Ground clearance:      7.9 in. (200 mm) 4WD/7.4 in. (188 mm) 2WD
Approach angle:      29 degrees 4WD/28 degrees 2WD
Departure angle:      26 degrees 4WD/25 degrees 2WD
Ramp break over angle:   19 degrees 4WD/18 degrees 2WD
INTERIOR DIMENSIONS
Headroom
Front:   40.0 in. (1,016 mm)/38.2 in. (971 mm) with sunroof
   Rear:         38.2 in. (970 mm)
Legroom
   Front:         41.3 in. (1,050 mm)
   Rear:         37.2 in. (945 mm)
Shoulder room
   Front:         56.3 in. (1,413 mm)
   Rear:         54.9 in. (1,394 mm)
Hip Room
   Front:         55.5 in. (1,409 mm)
   Rear:         44.0 in. (1,119 mm)
Interior volume:      125.4 cu. ft./122.9 cu. ft. with sunroof
SAE cargo index:   24.4 cu. ft. (rear seat up)/68.9 cu. ft. (rear seat down)
23.8 cu. ft. (rear seat up)/67.3 cu. ft. (rear seat down) with sunroof
CAPACITIES
Fuel tank:         17.4 gallons (66 liters)
Engine oil:         5.0 quarts (4.8 liters) with filter
Engine coolant:   8.6 quarts (8.2 liters)
CURB WEIGHT
RWD, manual transmission:   3,452 lbs. (1,566 kg)
RWD, auto transmission:   3,505 lbs. (1,590 kg)
4WD, manual transmission:   3,582 lbs. (1,625 kg)
4WD, auto transmission:   3,682 lbs. (1,670 kg)
TOWING
RWD, manual transmission:   3,000 lbs. (1,360.7 kg)
RWD, auto transmission:   3,000 lbs. (1,360.7 kg)
4WD, manual transmission:   3,000 lbs. (1,360.7 kg)
4WD, auto transmission:   3,000 lbs. (1,360.7 kg)
EPA FUEL ECONOMY ESTIMATES
Manual transmission:      18 mpg/city and 23 mpg/highway
Automatic transmission:
2WD:   19 mpg/city and 24 mpg/highway
4WD:    19 mpg/city and 23 mpg/highway
¹ESP is a registered trademark of DaimlerChrysler AG.
Offline Open4
  • Drive It! - Toyo!
    • Tint-it
Re: 2007 Suzuki GV Specs
« Reply #1 on: October 03, 2006, 01:24:07 AM »
Detail and sounds nice to have one. 8)
Yeah, why not!
