Coil spring spacer recommendations??
  • 3174 Views
Offline akfedor7
  • 62
« on: September 08, 2006, 05:41:50 AM »
I want to add some coil spacers to my kick. I checked with Digger, but he said the sport is made differently and the recommended modifications cant be made to this model. So I considered just using a 1" spacer which would hopefully be mild enough to use without any other modifications. Digger doesn't have any 1" ones, so what other companies have the best 1" spacers for the money? Thanks
1997 SIDEKICK SPORT, stock for now...
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
Re: Coil spring spacer recommendations??
« Reply #1 on: September 08, 2006, 11:43:23 AM »
Actually I beleive I told you that I didn't know if they would fit or not. I would hate to tell you one thing and be wrong when the truth is that I don't know. They probably will fit, but I don't have a sport model to test fit them on and I haven't had any reports back from anybody else that's tried using my spacers on a sport...
Offline akfedor7
  • 62
« Reply #2 on: September 08, 2006, 12:01:46 PM »
Yeah, I asked rocky road outfitters and they said theirs would fit a sport, so I'm sure yours would fit as well. But if I recall correctly you didn't have any 1" ones? I decided to go with 1" since the strut mount flip may not be possible. Do you plan on making any 1" ones in the near future? Thanks for your help.
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #3 on: September 08, 2006, 12:14:30 PM »
I'm not even sure what the ratio in the front is(size spacer x Y = total lift) I know the non-sport models are about 1.5 times the spacer thickness.  I'd try a 3/4" or a 1" in the front, and a 1.5" in the rear for an all-around 1.5" lift.
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #4 on: September 08, 2006, 02:25:53 PM »
Yes, they will fit a Sport. They use the same type off struts, shocks and springs. The only difference is the chassis width when it comes to fitting Calmini's diff drop brackets as they need modifying.
Offline akfedor7
  • 62
« Reply #5 on: September 08, 2006, 02:35:05 PM »
So then the strut mount flip will be the same?
sapien
« Reply #6 on: September 08, 2006, 03:44:26 PM »
if the Sport has a strut brace bolted to the upper strut mount then no.  but for 1" you don't really need to flip the mount.  I just put Digger spacers on my XL7, and I used Boondox strut extenders instead.
Offline Digger
  • 1991
« Reply #7 on: September 08, 2006, 09:49:15 PM »
I don't have any 1" material currently, but if there's call for it, I will get more...
