Samurai fuel problem...
  • 2846 Views
Offline fastchevy49
« on: September 08, 2006, 09:15:10 PM »
I have a '90 Samurai that just died the other day. I can remove the aircleaner and dribble gas into the throttle body and it will fire up until it burns up that gas, the fuel pump is working (I can hear it buzzing when the key is turned on).
I also loosened up the fuel line to the throttle body and it sprays out gas.
I have checked the wires going to the solonoid in the top of the T/B and when the test light is hooked to the "neg" side of the battery, neither wire is "hot"..but when I attatch the test light to the "pos" side of the battery the test light barely comes on when cranking the engine over while touching the solonoid wires!!??!!
When I bought this car two months ago the previous owner told me that the reason the horn and wipers didn't work was because the fuse box has some coorsion on the back of it, I tested the fuses and they are all good, and putting a fuse in the "ECM Test slot" gave me a code of..1..2..,I was told that 12 means everything is O.K.!!??!!
 I am at a total loss here and in a little bit of a bind..can anyone offer some more advice.
I really don't want to pay $212.00 for a fuel pump and after installing it, still have the same problem...but if ya'll think that is what the problem is..I will bite the bullet and go buy one..
Thanks for your help,
Russel
Offline holeypockets
  • 68
  • i think DENTS are pretty
Re: Samurai fuel problem...
« Reply #1 on: September 12, 2006, 08:33:03 AM »
try a new fuel filter,  sometmes they get clogged so bad no fuel can get through
i just like dents, i don't know why.
« Reply #2 on: September 12, 2006, 09:21:04 AM »
With the air filter off you should be able to see if the injector is spraying into the throttle body. The injector should have a 'permanently' live feed going to it, this is supplied from the Main relay, if you have no live feed then the main relay could be U/S. If the test light is lit then the ECU would seem to be switching correctly. The injector is switched on for a relatively short period that is why the test light is dim. Check the wires going to the TPS as well, this is off the same feed so one of them should also be live. It is not unknown for this feed to fail or for an open circuit to develop in the wiring. There is a work around that involves connecting the live wire on the injector to the ignition supply to bypass this. it might be worth trying that if you get nothing out of the injector.
Offline fastchevy49
« Reply #3 on: September 17, 2006, 08:16:00 PM »
I have checked all of the wires going to the TPS and the Injector and there is no power at anytime...not even when cranking.
Where is the "Main Relay" located and how can I "by-pass" it??
Which wire do I need to put the 12 volts to? (what color)?
Thanks for all the help...
Russel
