Lockrite
  • 17 Replies
  • 4884 Views
Offline TysonS
  • 383
  • www.funinbc.com
Lockrite
« on: September 11, 2006, 04:55:01 PM »
Can i put a lockrite from the rear of a sami into the rear of my kick without any modifications?  Easyer just to get the one made of a kick ???
thanks
Offline TysonS
  • 383
  • www.funinbc.com
Re: Lockrite
« Reply #1 on: September 11, 2006, 07:54:17 PM »
i know someone on here knows  ::)
Offline zukisidekick
  • 85
Re: Lockrite
« Reply #2 on: September 11, 2006, 09:14:37 PM »
Hi Tyson,
Nope, gotta use the kick lockrite.   Stinks...I had a Sami locker laying around, and had to buy another for my kick.... :-\
-Zukisidekick
Offline TysonS
  • 383
  • www.funinbc.com
Re: Lockrite
« Reply #3 on: September 11, 2006, 09:15:40 PM »
ok, thank you
Offline 89tintop
  • 356
Re: Lockrite
« Reply #4 on: September 11, 2006, 09:20:52 PM »
get the trail tough spool instead, its alot less $$ and it drives very well on the street, I also run 30's on my daily driver with a spool with no turning problems at all and so much easier to install and spools last forever. my $.02 ;D
91 kick 4 door 2 inch body lift, 2 inch spacer lift, 31's.
Offline flexmonger
  • 209
  • live to wheel and wheel to die.
Re: Lockrite
« Reply #5 on: September 11, 2006, 10:51:59 PM »
  Bull hockey, you can use a sammi rear lock rite in a kick diff. I have did it on both kick diffs I owned. The side gears must match your lock rite or use your old ones. Buy new side gears if you can for extra endurance.
Offline Quaddawg
  • 1622
    • My Ebay Store
Re: Lockrite
« Reply #6 on: September 12, 2006, 04:53:08 AM »
That's my vote too.  I run the mini-spool in my green "turtle" and it actually does just fine on road.
Offline Sammy N Austin
  • 16
Re: Lockrite
« Reply #7 on: September 12, 2006, 08:23:08 AM »
How does a mini spool work and how is it better? Is it appropriate for the front also?
88.5 Samurai Soft Top
97 LX450
Offline Jimiweld
  • 234
    • www.fullfusion.ca
Re: Lockrite
« Reply #8 on: September 12, 2006, 09:18:32 AM »
I thought the mini spool locked everything up solid in the rear, how is that for turning on dry pavement? If it's good I'd put one in, I hear so many conflicting opinions about the lockright
Re: Lockrite
« Reply #9 on: September 12, 2006, 10:58:27 AM »
The spool does just lock your rear end solid.  It isn't bad, but it does tend to chew your tires up a little faster and you squeak a bit when making tight corners.  But the behavior is pretty tame, as it will always act the same.
Then again, with 30" tires you shouldn't have a much of a problem with the lockright binding up in the rear.
Offline Jimiweld
  • 234
    • www.fullfusion.ca
Re: Lockrite
« Reply #10 on: September 12, 2006, 11:34:55 AM »
"Then again, with 30" tires you shouldn't have a much of a problem with the lockright binding up in the rear."
What does the tires size have to do with binding?
Offline TysonS
  • 383
  • www.funinbc.com
Re: Lockrite
« Reply #11 on: September 12, 2006, 04:23:00 PM »
i don't care, im getting a lockrite  ;D
Looks like im going to get one made for my trackick tho
Offline stock93tracker
  • 309
Re: Lockrite
« Reply #12 on: September 12, 2006, 04:26:21 PM »
Im gonna break down and buy a spool I think..  I heard they are kinda sucky on wet or snowy roads though.
But hey, for 100 bucks, a fully locked rear is priceless offroad.  After I get the 30" tires next spring to replace my running-down 235's I got now  I wont have anything else on my list of things to get.
93 Geo Tracker
-2" Lift
Re: Lockrite
« Reply #13 on: September 12, 2006, 11:22:55 PM »
Smaller tires means less stress.  I think that is how it goes...
One thing about the spool, you increase your turning radius a bit by using one  :)
Offline vitara-dave
  • 11
Re: Lockrite
« Reply #14 on: September 13, 2006, 02:50:53 PM »
The lockright itself from a sam or a kick are the same. I don't know about the sidegears bcoz i bought them without. Anyway I had a sam lockright and a kick lockright and i coud not find the difference...
