G/V air actuated diff pix.
  • 33 Replies
  • 8192 Views
0 Members and 14 Guests are viewing this topic.
Re: G/V air actuated diff pix.
« Reply #30 on: January 26, 2005, 06:42:08 AM »
And for Rhinoman   :P
I did read it right
Ooops so you did  :-[. I was reading:
"The G/V left is 40mm longer than the Escudo and the G/V right is 18mm longer"
If the shaft is longer then the CV would be further into its housing and the angle would be better, that got my attention.
I stripped the left hand and right hand Track/Kick/Vit shafts that I had here to see if I could build a longer shaft by mixing and matching but the shaft part was the same length. When I got the guy in the breakers to compare GV and Track/Kick shafts for me he reckoned they were all the same. He obviously didn't look too closely  :( Of course he wasn't going to strip any down and clean them up to do ::)
« Last Edit: January 26, 2005, 06:42:48 AM by Rhinoman »
Offline blacknight
  • 987
    • Gonzookin
« Reply #31 on: January 26, 2005, 11:53:26 AM »
BTW
I use my 1/2" an 13MM  wrenches interchagably
but a 12mm is too loose on a 7/16" nut/bolt ???
So size it as you will, I just can't use my 12mm
for a 7/16" bolt head but I can use a 13mm on
a 1/2"    ;)
And for Rhinoman   :P
I did read it right
25.4 mm = 1 inch so 12/25.4= 0.47244094488188976377952755905512in
I let you do the rest of the math to get a faction  ::)
« Reply #32 on: January 26, 2005, 01:19:22 PM »
The unit of measure was 16ths
not 12ths, now assuming that
25.4mm = 1"  which I think is
correct  1/16" = 1.5875 mm
7 * 1.5875 = 11.1125
So then 8/16" or 1/2" =12.7mm
That would be why I can use a 13mm
wrench on a 1/2" bolt but a 12mm is
too loose on a 7/16" bolt
But it would be so much easier if we
just all used metric units instead of
this horrid mix of sizes
Offline blacknight
  • 987
    • Gonzookin
« Reply #33 on: January 26, 2005, 11:16:58 PM »
I hear you on that!
George
