anyone have measurements this exact set-up on a Track/Kick:
  • 1886 Views
Offline stock93tracker
  • 309
« on: September 12, 2006, 03:44:14 PM »
Stock Suspension, 15 x 7" wheels, 235/75/R15's
If some one has this particular setup on their rig can I get measurements from the ground to specific body points?
It looks like my front lift has sagged in a bit but..  I took measurements all over and they all almost equal out to before (rear 1/2 inch higher all the way around)
Can I get some measurements from others just to be sure im in the ballpark of lift I have total? (I forgot to do before and after measurments with the lift, so I need the before)  Im looking mostly for the ground to the top of wheel well and ground to bottom of rocker panels on the side..
Thanks, I think Its just my imagination thats its sagged a bit (pyschological, you know.  I feel as if its STILL not high enough and my mind plays tricks on me)
93 Geo Tracker
-2" Lift
Offline cj
  • 1276
  • I drive a really big ATV
Re: anyone have measurements this exact set-up on a Track/Kick:
« Reply #1 on: September 12, 2006, 03:53:01 PM »
It doesn't matter what size rubber you have. The following measurements are from Suzuki for a stock vehicle. Measure from the center of the hub to the top of the wheelarch then subtract the figure below and that will tell you how much difference between the as new stock suspension and where yours is at.
Front:  18" (swb)          17.9" (lwb)
Rear :  19.6" (swb)       18.1" (lwb)
  • 309
« Reply #2 on: September 12, 2006, 04:03:28 PM »
cool..  thanks man!  I just have to compensate for the 235's extra height now and subtract.
(anyone know the height of a 235/75 vs. a stock 205/75?)    ;D
93 Geo Tracker
-2" Lift
Offline cj
  • 1276
« Reply #3 on: September 12, 2006, 04:36:11 PM »
No, if you do what I said above it doesn't make any difference what size rubber you have as you are not measuring from the ground.
Offline cj
  • 1276
« Reply #4 on: September 12, 2006, 04:44:37 PM »
Fitting larger rubber has no effect on your suspension height but keep in mind that not all rubber measures what you think it might/should. Also the measured dia. given by the manufacturer is for a stated rim width and pressure. If you have varied these then the dia. will be different to what they quote.
  • 309
« Reply #5 on: September 12, 2006, 04:55:14 PM »
my bad.. Im in class right now and am typing fast..
Thanks for the measurements.  Ill check them out..   ;D
Gotsta read and type fast while Im here...
93 Geo Tracker
-2" Lift
