Vacuum pump, any way to test?
  • 2293 Views
Offline lowrezolution
  • 292
  • "Get bent!"
« on: September 12, 2006, 05:29:23 PM »
Is there a good way to test the vacuum pump mounted to the front bumper to see if its pulling good vacuum?
Can it be ditched for a mechanical system? I think a mechanical engaging system would be much more reliable and you would be 100% sure its engaged.
Any help would be good as I'm ready to beat it into submission with the 20 lb swing press!
2001 Tracker LWB
Boondox coil spacers and BDS springs 3.25" rear lift/3" front lift,3" body lift. 265/75/16 Durango Mud Terrains. (32")
Offline derekj
  • 784
  • i'm the canadian guy eh?
Re: Vacuum pump, any way to test?
« Reply #1 on: September 12, 2006, 10:47:30 PM »
just put a vacuum gauge/pump on it to make sure you are getting good vacuum from the engine and then put the pump onto the unit and apply vacuum using the pump and see if it engages ok. there is a company that makes a mechanical system but only for full size american trucks..... can't seem to remember the brand.
derek
91 Sidekick jx
2" BDS supension lift
2" BDS body lift
1" Coil spacers
« Reply #2 on: September 13, 2006, 04:35:01 AM »
vacuum pump?
  • 292
  • "Get bent!"
« Reply #3 on: September 13, 2006, 01:23:27 PM »
Is it vacuum or pressure operated?
2001 Tracker LWB
Offline derekj
  • 784
« Reply #4 on: September 13, 2006, 10:05:25 PM »
a hand held vacuum pump will have a vacuum gauge on it as well. it can be used for applying vacuum to a solenoid or valve or to measure how much vacuum you are getting at a certain component.
derek
91 Sidekick jx
2" BDS body lift
1" Coil spacers
« Reply #5 on: September 14, 2006, 04:41:23 AM »
If you are referring to the front diff actuator then its pressure operated. I have this set up on mine but I've no idea where the pump was located on the original vehicle. You should be able to feel pressure if you put your finger over the outlet. If the diff isn't functioning correctly then I suspect an air leak.
  • 292
  • "Get bent!"
« Reply #6 on: September 14, 2006, 11:53:17 AM »
rhinoman,
Are you sure it's pressure and not vacuum? I blew up a small ballon and placed it over the line the line to the diff (on the pump) and it evacuated it and started pulling the ballon in the line!!!
I'm taking it to a friends shop tonight, going to get to the bottom of it!!!
2001 Tracker LWB
« Reply #7 on: September 14, 2006, 02:57:53 PM »
rhinoman,
Its 11pm Thursday here, I'll double check it at the w/e.
  • 292
  • "Get bent!"
« Reply #8 on: September 14, 2006, 04:22:37 PM »
rhinoman,
Just got back from my friends shop, put a vacuum gauge on the pump, it pulled 10" of vacuum. Installed a hand operated vacuum pump and pulled it all the way to 30" of vacuum, diff won't engage.
I guess I'll have to open it up and see whats going on!
Any body have a blow up of the front diff in a 99-05 tractara?????
2001 Tracker LWB
