distributor o-ring
  • 3097 Views
Offline KickTurn
  • 53
  • My wife likes the smell of petroleum products.
distributor o-ring
« on: September 12, 2006, 10:29:22 PM »
I'm replacing the distributor shaft and housing o-rings on my 95 Sidekick.  The new o-ring from Hawk really doesn't want to go into the bore of the housing.  I've tried lubing it up with both engine oil and silicone.  The old one has a smaller outside diameter.  Are there slight differences in distributors or distributor shaft o-rings across years?
95 Kick JLX 4x4 4dr 1.6 16v.
235s, manual hubs.
Offline derekj
  • 784
  • i'm the canadian guy eh?
Re: distributor o-ring
« Reply #1 on: September 13, 2006, 10:09:19 PM »
i have found that a nice thin bead of silicone on the distributor works quite well also. when i fixed mine i had to reuse the o ring as we did not have anything that matched it exactly. it's not leaking yet............
derek
91 Sidekick jx
2" BDS supension lift
2" BDS body lift
1" Coil spacers
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
« Reply #2 on: September 14, 2006, 09:19:34 AM »
yep siliconed up my samurai year ago, no leaks yet.
Offline crikeymike
  • 713
    • http://www.wazuks.com
« Reply #3 on: September 14, 2006, 11:09:08 AM »
i got mine from hawk too and had exactly the same problem.  I actually created a hairline crack in the distributor shaft from trying so hard.
I verified the part number and it was correct.  I just reinstalled the original anyway, as it wasn't leaking, it was the housing o-ring that was causing a leak on mine.
It definitely seemed a little too thick to me also...  they recommended grease to me to get it to go in.
1993 4-door Sidekick
4.24:1 t-case
Offline 89tintop
  • 356
« Reply #4 on: September 14, 2006, 11:13:24 AM »
just use high temp on it and call it a day, i never replace those orings just high temp it.
91 kick 4 door 2 inch body lift, 2 inch spacer lift, 31's.
Offline KickTurn
  • 53
« Reply #5 on: September 14, 2006, 11:20:36 PM »
Thanks for the replies.  I think I am going to try a smaller o-ring for a start.
235s, manual hubs.
