Water leak on the floor
  • 16 Replies
  • 3589 Views
Offline CJ11
  • 157
  • 95 SIDEKICK ON 31'S
« on: September 15, 2006, 05:14:55 PM »
Ok my next problem I have had 3 kicks now and all 3 leaked the bulk of it seems to run in down the fire wall and fill up the floor with water.  Does any one know where the water comes from and how to stop it.  I think some silicone would stop it and i am sure someone else has had the same problem so please help thanks........CJ
« Last Edit: October 05, 2006, 02:17:26 PM by CJ11 »
Offline ZeusZuki
  • 411
Re: Water leaking down firewall
« Reply #1 on: September 15, 2006, 05:35:11 PM »
Hi cj11,
I too have had this happen. Tracked it down to the drain bungs in the fresh air intake being blocked ( the grill bit behind the bonnet and below the wind screen ) - cleaned them out and problem gone  :)
Also happened when the front disappeared during a river crossing  ??? with the heater set on "fresh air intake" LOL  ::)
ZeusZuki  8)
Offline Quaddawg
  • 1622
    • My Ebay Store
« Reply #2 on: September 15, 2006, 05:41:18 PM »
"( the grill bit behind the bonnet and below the wind screen )"
or, as we say here in the States,   the grill part, behind the hood, and under the windsheild...  (lol)
Offline CJ11
  • 157
« Reply #3 on: September 15, 2006, 05:42:19 PM »
Do you mean the vent below the wipers do I have to get that off and clean in there.
Offline CJ11
  • 157
« Reply #4 on: September 15, 2006, 05:43:49 PM »
thanks for that Quaddawg was not sure what hte hell he was saying.
Offline ZeusZuki
  • 411
« Reply #5 on: September 15, 2006, 05:56:19 PM »
LOL - yeah that bit  ;D
Every year I go down to Antartica doing some work for the Yanks - they wander What The F|removethispart|@$K I am talking about too - good bit of humour LOL ( actually pissing my pants with laughter right now ). The ones that know me just say " don't worry about him, he's a KIWI"  :)
You guys  ;)
CJ11 - no just hose it out after you have cleaned out the drain bungs ( if that is what you call bungs  ;) )
ZeusZuki  8)
« Last Edit: September 15, 2006, 05:58:11 PM by ZeusZuki »
Offline CJ11
  • 157
« Reply #6 on: September 15, 2006, 06:12:37 PM »
I am only joking with you Zeuszuki thanks for the help I hope this works f*#king sick of the water.
Offline CJ11
  • 157
« Reply #7 on: September 15, 2006, 08:17:21 PM »
pulled it all apart and if you are talking about the 2 notches under the plastic cover they are clean nothing in there at all it is raining here and they are dry inside. Any other ideas on where the water could come from.
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #8 on: September 16, 2006, 11:10:00 AM »
Take your fenders off and check behind them on the bit of the firewall that the fenders cover about 2' below the windshield.  Did this recently with my '96 and yeah...had some spooky rust there.  I bet if I took my '90's fenders off I'd find holes.  Anytime it rains that thing has water slooshing around in the footwells.
I was convinced it was a windshield seal problem until I took the fenders off and saw that. :P
I cleaned the rust up really well on mine on both sides, hit it with Chassis Saver to stop the rust, and then globbed Herculiner into every bit of it when I did the rest of the body.  That should stop the leaks.
I've also seen people use silicone sealant on other vehicles.
Offline ZeusZuki
  • 411
« Reply #9 on: September 16, 2006, 01:45:17 PM »
You got me then  :-\ .
Bucket of Fido  ::)
ZeusZuki  8)
Offline suzukiboyoz
  • 194
  • Friends don't let friends ride a Yamaha
    • http://community.webshots.com/
« Reply #10 on: September 20, 2006, 03:32:43 AM »
Have you put anything thought the main wirering harness rubber boot like uhf lead, spotlight wires, etc.
Water will run off the edge of the rubber seal at the back of bonnet under the front window and straight onto the harness travel along and into the car.
Calmini 3" Suspension Lift, Calmini Skid Plates, Calmini Rockhoppers, 30" Mud TYres, ARB Bullbar, Rear ARB Locker, Custom Sill Sliders, Rear Bumper and a lot more.
Offline CJ11
  • 157
« Reply #11 on: September 20, 2006, 08:11:12 PM »
That is coverd with silicone I have checked every where and nothing so i ran some silicone under the windsheild on the out side looks like that might be the spot. Well i will find out next time it rains..
Offline CJ11
  • 157
Re: Water leak on the floor
« Reply #12 on: October 05, 2006, 02:19:58 PM »
I have tried everything silicone all over and totaly resealed the windows on the hard top stoped the leak in the back but still leaking in the front.  Where the hell is it comeing from can any one help please. chris
Offline Jimiweld
  • 234
    • www.fullfusion.ca
« Reply #13 on: October 24, 2006, 10:16:46 AM »
I'm having the same issues with my tracker leaking and have tried all the remedies listed here to no avail. I was wondering if you figured out what it was yet CJ11 before I take my dash apart to find the leaks?
Jim
  • 6597
  • 68
« Reply #14 on: October 24, 2006, 10:40:37 AM »
Or...
Cowl [koul] [Origin: bef. 1000; ME cou(e)le, OE cugele, c?le < LL cuculla monk's hood, var. of L cucullus hood] The part under the behind the hood but before the windshield. The top portion of the front part of an automobile body, supporting the windshield and dashboard.
« Last Edit: October 24, 2006, 10:42:26 AM by ebewley »
