track/kick/vit millage per tank??
  • 16 Replies
  • 4527 Views
Offline skandy32
  • 93
  • Zukiworld Rocks!
    • Andy Colver Photography
« on: September 18, 2006, 10:57:10 AM »
Wello guys, basically, i've recently started to think my 8valve vit/kick is draining me of fuel farrrr more than it should. I love driving it, but its eating my wallet!!
I get about 160 miles per tank. My fuel guage has now eventually packed up, so it'd be scary to run it any longer before a re-fill! I also have a speed limit of 35mph all over the island i live on. So i drive up to about 60mph on a regular basis :P, and offroad 20% of the time. Whether this makes much difference...??
So...
How many miles do you in yours??
What can i do to make it any better?
(i already have just installed a complete calmini exhaust/de-cat pipe, with normal air intake, but this hasnt changed the efficiencey)
Andy :)
UK Vitara - 2" spring/shock spacers, 3" calmini body lift, 32x11.5x15" BFG MTs, rear half calmini exhaust/no cat, full Alpine ICE
http://www.andycolver.co.uk
Offline Carnage
  • 2453
Re: track/kick/vit millage per tank??
« Reply #1 on: September 18, 2006, 11:07:42 AM »
My 16v 4 door auto gets 22mpg on 18s with a really heavy foot
(i might change my O2 and see if that helps)
X32...................X32CarDomainPage...................X32
...................RyouBakua|removethispart|@Hotmail.com..................
Help me Heal!!!!!! CLICK HERE!!!!!!!!!!![/color]
Join the new Galactic Empire!!!!!!!!!!!![/color]
« Last Edit: September 18, 2006, 11:10:21 AM by Gen-Erix »
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« Reply #2 on: September 19, 2006, 02:42:47 PM »
I got 28-30 (usually 29+) mpg in my '96 1.6 liter with stock tires, then an *indicated* 25 with 235/75 Dueler M/T tires (so probably more like 27 actual).
I got 26+ in my 03 swb with the 2.0 on stock tires, then right around 25 (actual) with the same 235's.
Now I've got the 2.7 v6 running in the 03 swb, through the stock 2.0 4-cyl's exhaust, and I'm getting 21-23 mpg on stock tires.  Hopefully that'll improve some when I uncork it with a more reasonable exhaust setup.  Then, of course, I'll give it right back again with taller tires..
XL-7 front coils
1.5" rear coil spacers
Offline stock93tracker
  • 309
« Reply #3 on: September 19, 2006, 02:58:22 PM »
I get roughly 20 MPG..  its dropped since ive got it but, I dont care to spend a lot to figure out why
93 Geo Tracker
-2" Lift
Offline skandy32
  • 93
  • Zukiworld Rocks!
« Reply #4 on: September 19, 2006, 03:24:41 PM »
mpg! theres a good way to measure, i completely missed it out.
Am i right in thinking a usa gallon is ~ 3.7lts and a uk one ~4.5lts? Whcih means some of your replies will be a fair bit different to mine.... am i working this out correctly too?
a full tank costs me £21, at about 0.53p a litre...
so 21.00 / 0.53 = 39.6 (size of my tank? 40lts i guess)
39.6lts / 4.5 = gallons? = 8.8
mileage 160 / 8.8 = MPG ( tell me if my working out is wrong!)
MPG = 18.8
Thats CRAP! surely!?
Is there anything simple i can do to increase this?
Also with my fuel guage not 100% working, how big is a tracker fuel tank?
Would driving under 40mph lower my MPG ? could just be down to this...
Andy :-[
Offline Carnage
  • 2453
« Reply #5 on: September 19, 2006, 04:31:18 PM »
driving under mph will almost ALWAYS lower gas mileage
faster you go, more gas you burn
estimated MPG on all vehicles is based on strict adherance to speed limits
Offline strvger
  • 95
  • Livin' on the edge... of the Great Northwoods !!
« Reply #6 on: September 19, 2006, 05:31:21 PM »
1991 Tracker, 1.6, 8v, 30" tires, stock gears (5 speed).  i get about 30mpg (US) when cruising the freeway at 62 mph indicated.  this is actually closer to 66 mph or so.   i go 300+ miles everyother weekend and can do it on one tank.   if my math is close, that's about 110kph and about 500 klicks per  tank.  ;D
'91 tracker, 1.6 8v 5-spd, 1.5 in susp lift,  DT header and 2 in exhaust, 235/75 AT's on 15x7 Turbines, 1st prototype: Ibuiltbumpers.com trackick front bumper!,  other mods coming soon!
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #7 on: September 19, 2006, 06:29:17 PM »
Have you done a tune up? Plugs, wires, o2 sensor....
Offline WorkInProgress91
  • 31 gets it done
« Reply #8 on: September 19, 2006, 07:02:53 PM »
Since i installed the new exhaust and replaced the 02 sensor, my 2 dr 8v kick is getting about 22 mpg measured with 31'' swampers, so im guessing that works out to about 24ish mpg.
91 sidekick
2'' B/L, 2'' coil spacers
31'' swampers
winch
custom bumper tank lift camouflage duct tape
Offline urbanwheeler
  • 696
« Reply #9 on: September 20, 2006, 01:48:02 AM »
I got 29.7 today, and that is with it running wierd :P. I have found that I get my best mileage when I am above 4000 feet elevation.
« Reply #10 on: September 20, 2006, 04:55:09 AM »
......... how big is a tracker fuel tank?
This is very true, 'they' get less miles per gallon. Also their tanks are bigger too, a Vitara has a 9.2 gallon tank.
Offline skandy32
  • 93
  • Zukiworld Rocks!
« Reply #11 on: September 20, 2006, 07:19:25 AM »
nope, never changed any of this since i've owned it for the last year. Would replacing these with new bits improve it?
thanks for the replies so far... very helpful :)
Offline Carnage
  • 2453
« Reply #12 on: September 20, 2006, 08:37:10 AM »
it sure should
although im not sure how much O2s go for
(someone must know though)
« Reply #13 on: September 20, 2006, 09:21:06 AM »
I picked a new O2 sensor from eBay for £6, NOS from a dealer. I've seen them advertise them a few times. Its best to replace the O2 sensor last, if the engines a bit out of tune its possible to damage the sensor.
« Reply #14 on: September 20, 2006, 10:33:51 AM »
The first thing I do to a vehicle that is underporforming is the plugs, wires, cap and rotor.  Usually fixes it as well.  Had a friends Zuki get to the point where it wouldn't do over 40 because half the plug wires were shorting out...
I usually get around 28-30mpg on a stock 96 2 door Tracker with the 16v after I make up for the difference in tire sizes.
