how much oil in front diff?
  • 17 Replies
  • 8693 Views
Offline beerman
  • 339
  • Suzuki 4x4 Norway
    • www.tristania.com
« on: September 21, 2006, 04:49:32 PM »
i'm going to change the oil in the front diff, the first thing i heard of when i bought my GV was the front diff.
i know that i should overfill, but how much??
my vitara consultant won't pick up the phone (vonder why ;D)
i THINK the oil level should be at the TOP of the filling hole, how high should i lift it in the front?
my GV is a 1999 2.0 TD if that makes any difference, think it was in 2001 they relocated the filling hole?
think i need bigger tyres and spring lift....
Offline IanL
  • 466
Re: how much oil in front diff?
« Reply #1 on: September 22, 2006, 01:26:21 AM »
1.0 litre
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #2 on: September 22, 2006, 06:43:12 PM »
The word I read somewhere around here was that you guys with the "low fill plugs" were supposed to jack the front of the truck up a bit, fill to the line, replace the plug, and then lower the truck.  That way you get extra fluid in there.
I dunno how high you should jack it up though.  Maybe measure the difference between a newer GV and yours and jack it up so that the fill plug is at that height?
Offline IanL
  • 466
« Reply #3 on: September 23, 2006, 12:59:55 AM »
I haven't heard about "low fill plugs".  My Suzuki FSM just says have the vehicle level and fill to the hole.
Where does the advice to "overfill" come from?
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #4 on: September 23, 2006, 07:49:52 AM »
At least here in the States the first couple model years had the fill plug a bit low.  This lead to some of the front end problems the 99's, 00's, etc have had.  Part of the fix that I've heard about is to simple overfill them.  If you compare say a '99 to a '03 you'll notice the fill plug location is higher...at least here in the States.
Offline IanL
  • 466
« Reply #5 on: September 24, 2006, 02:21:21 AM »
Sounds like I should be concerned.  My 2.5 litre is a '98 (we got them a year before you) and the PO said it was built in Canada.
The VIN starts JSAFTD62V00 - anyone know if that's Canada or Japan built?
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #6 on: September 24, 2006, 06:58:56 AM »
Ours starts like that and it was made in Japan I beleive.  I think JS is Japanese and the Canadian made ones start with something else.  Although I wasn't aware if the Suzukis were made by CAMI, I thought only the Trackers were.
Offline r3cc0s
  • 321
« Reply #7 on: September 24, 2006, 08:23:31 AM »
Jack the car 30degrees and then fill
The anvil's resovoir and plug design does not provide the front diff with enough oil
Offline blacknight
  • 987
    • Gonzookin
« Reply #8 on: September 24, 2006, 12:47:31 PM »
All so the 30 deg. thing was fixed in 2002.  If you look at your diff and see a casting for a 2nd  hole just below the fill hole you don't need to jack the front up.  Just fill it till oil starts to come back out the hole.
George
Offline beerman
  • 339
  • Suzuki 4x4 Norway
    • www.tristania.com
« Reply #9 on: September 25, 2006, 09:15:50 AM »
George
thank you! will trye to change the oil later this week...
Offline blacknight
  • 987
    • Gonzookin
« Reply #10 on: September 25, 2006, 11:11:12 AM »
From the FSM
Specified gear oil: Hypoid gear oil API GL-5
SAE 75W – 85, 90 or 80W – 90
For oil viscosity, refer to left chart.
Oil capacity: 1.0 liters (2.1/1.8 US/lmp. p
« Last Edit: September 25, 2006, 01:18:52 PM by blacknight »
Offline beerman
  • 339
  • Suzuki 4x4 Norway
    • www.tristania.com
« Reply #11 on: September 25, 2006, 12:31:41 PM »
WOW, that much oil?
i havent looked that much in the FSM yet, but think it is supposed to be 1,5 or 1,7 litres in the gear box. changed at the transfer when i had to remove the gearbox earlyer this year, just the rear diff left then :)
Offline IanL
  • 466
« Reply #12 on: September 25, 2006, 01:13:36 PM »
From the FSM
SAE 75W-85, 80W-90 or 90
For oil viscosity, refer to the chart
at the left.
Oil capacity : 2.2 liters (4.6/3.9 US/Imp. pt.)
From my FSM, the capacity of the FRONT Diff is 1.0 liters (2.1/1.8 US/Imp pt)
The capacity of the REAR Diff is 2.2 liters (4.6/3.9 US/Imp. pt.)
Manual Gearbox is 2.7L
Transfer is 1.7L
« Last Edit: September 25, 2006, 01:15:53 PM by IanL »
Offline blacknight
  • 987
    • Gonzookin
« Reply #13 on: September 25, 2006, 01:19:40 PM »
sorry about cut and pasted the wrong line  :-X fixed it now
George
Offline JDMCRX
  • 1110
  • 02 Grand Vitra Pimp lol
« Reply #14 on: September 25, 2006, 02:40:25 PM »
Front diff OVER fill it. Put about 1.2-1.3 this works it was posted here before. Every diff we did 1L is fucked. My dads xl7 and other friends GV we did 1.2-1.3 and no probs with failure.
Posted awhile ago i dunno if it was SUZUKI portagal. Or some were else they said to jack the truck in a certin deg incline and fill it up 1.3L
01 GRAND VITARA
