Engine Hesitation?
  • 1846 Views
Offline Stinger
  • 15
Engine Hesitation?
« on: September 27, 2006, 12:35:53 PM »
My engine is having a lot of hesitation problems at lower rpms. I reset the valves to spec and have 120 lbs compression on all cylinders. I changed out the fuel filter and have sprayed lots of carb cleaner in the carb. Still nothing helps. Where should I look from here? I was told possible accelerator pump, is there any way to check it? Any info and advise would be appreciated. Thanks  The truck is a 88 samurai with the 1.3l
Offline Element
  • 1902
  • LillyKicker
Re: Engine Hesitation?
« Reply #1 on: September 27, 2006, 01:07:30 PM »
Would the venturi tube help this problem any? I know it helps with flat spots in exceleration
zUkTAH
U4WDA
« Reply #2 on: September 28, 2006, 02:59:28 PM »
ya the tube helped mine alot but his sounds more like the accel, pump.  I think suzuki Johns in las vegas sells just the pumps. you could look down the inside of the carb and see if it is working.
Offline Element
  • 1902
  • LillyKicker
« Reply #3 on: October 14, 2006, 08:26:50 AM »
Throwing a venturi tube in mine today, I will let you know what I think!!!
zUkTAH
U4WDA
