what year trackers have 4.62 gears
  • 14 Replies
  • 3338 Views
Offline kymike
  • 87
« on: October 03, 2006, 04:57:12 AM »
please let me know make and model
Offline bzzr2
  • 1011
Re: what year trackers have 4.62 gears
« Reply #1 on: October 03, 2006, 09:01:22 AM »
03 zr2 5spd has 4.62's
09 taco reg cab short box 4x4
Offline Allan
  • 30
« Reply #2 on: October 03, 2006, 01:00:12 PM »
My Sammy has 5.12 diff gears, Can I change this to 4.62 diff gear? How I can do that?
Wich is the diference bettwen 5.12 and 4.62 diff gears?
Offline da_tub
  • 307
« Reply #3 on: October 03, 2006, 04:58:50 PM »
didn't most of the auto trans two doors have  4.62's?
91 four door ,and some stuff
« Reply #4 on: October 04, 2006, 06:39:13 AM »
   I believe the 2 dr auto 8valves have 4.62 gears and 2dr auto 16 valves have 4.30.
« Reply #5 on: October 04, 2006, 08:09:04 AM »
Mike, I finally got some 4.62s, get back with me and we'll try to work something out on the swap.
Offline Allan
  • 30
« Reply #6 on: October 04, 2006, 02:06:45 PM »
Somebody can answer my quiestion?
Offline wolf66
  • 193
« Reply #7 on: October 04, 2006, 02:20:43 PM »
4.62 is taller gearing (ie u go faster at same rpm as 5.12's) but with some power loss compared to 5.12's
5.12 is lower gearing, ie more torque and power but higher RPM at same speed as 4.62's
Most 4x4's want the lower gears, esp when you add bigger tires as this acts like a taller rear gear resulting in power loss....
'96 Suzuki X90-4" lift-snorkle-30x9.5's on 8x15 wheels-5.12 gears-winch-added rear seat-DT header-PioneerMP3-CB-GPS-roof rack-rear mounted full size spare
« Reply #8 on: October 04, 2006, 02:23:56 PM »
Yes, you can change them out for 4.62s.  You will do the same procedure as was used to install the 5.12s.
The difference?  Not really sure what you are asking....???
Offline Allan
  • 30
« Reply #9 on: October 05, 2006, 03:00:17 PM »
Thanks for the answer, the diference bettwen 5.12 and 4.62 diff gears, I refere for example in the 5.12 My Sammy has 41 teeth  - 8 teeth  gears in the diff, in the 4.62 wich is the combination?
« Reply #10 on: October 05, 2006, 07:51:20 PM »
37 and 8
Offline Allan
  • 30
« Reply #11 on: October 06, 2006, 10:43:09 AM »
If I want change it to 4.62, can I will use the original housing of Sammy?
« Reply #12 on: October 06, 2006, 11:10:12 AM »
Yes.
If you want more info, PM me.  I don't want to clutter up Mike's thread.  ;D
Offline Allan
  • 30
« Reply #13 on: October 06, 2006, 11:37:09 AM »
Yes I want to know more, what I do?  Sorry what is "PM me"?
« Reply #14 on: October 06, 2006, 11:42:07 AM »
Click on the little blue or gray (depending whether I am online or not) spot below my username that has the letters "IM" on it.  Then you can send me a PM (private message) or IM (instant message).........both are the same thing, they are just named different.
« Last Edit: October 09, 2006, 07:11:14 AM by Skyhiranger »
