flashing od off light and engine runs bad
  • 2510 Views
Offline f45bob
« on: October 03, 2006, 10:54:22 AM »
here is the thing after a oil change and tires rotated it started flashing the od off light and runs real bad. mecanic had me change the cataletic converter and no change and a mass air sensor and no change. the engin runs fin for a minut after starting then the flashing starts and it goes back to runuing badly pleas help
Offline f45bob
Re: flashing od off light and engine runs bad
« Reply #1 on: October 03, 2006, 03:16:32 PM »
Iguess it would help if I said it was a 91 sidekick jlx
Offline wolf66
  • 193
« Reply #2 on: October 04, 2006, 02:23:22 PM »
flashing OD light is related to tranny problems, don't know why it would run bad at the same time though
'96 Suzuki X90-4" lift-snorkle-30x9.5's on 8x15 wheels-5.12 gears-winch-added rear seat-DT header-PioneerMP3-CB-GPS-roof rack-rear mounted full size spare
« Reply #3 on: October 04, 2006, 02:48:36 PM »
Does this happen wether you have the OD on or off?
Offline f45bob
« Reply #4 on: October 05, 2006, 08:37:50 AM »
yes it does not mater if the od off is on or off.
« Reply #5 on: October 05, 2006, 10:42:59 AM »
Try pulling apart your shifter and disconnecting the switch, see if it still happens.
Offline f45bob
« Reply #6 on: October 06, 2006, 08:21:16 PM »
the thing is it works fine for about 2 min after start up then poop and flashing and run bad
« Reply #7 on: October 09, 2006, 10:42:02 AM »
It may be that your computer is waiting for your engine to warm up.   I would disconnect the overdrive switch completely in order to remove it from the equation.  Once that is done you can work on troubleshooting the rest of the electronics.
