Idle-up
  • 1827 Views
Offline Skeeter
  • 23
Idle-up
« on: October 03, 2006, 03:22:45 PM »
I have a 1985 Sierra/Samurai. When you turn the headlights on, the engine idle goes up. Is there a way to switch on this "idle-up" without turning the headlights on? I want to make the idle go up to around 1500rpm when I turn on my 12v compressor, but I don't want it at 1500rpm everytime I turn on the headlights.
Hope that makes sense
Skeeter
Offline Skeeter
  • 23
Re: Idle-up
« Reply #1 on: October 08, 2006, 04:02:57 PM »
Can I just cut one of the wires that runs to the "idle up" solenoid & put a switch "inline"?
Cheers
Offline RGERBER
  • 81
Re: Idle-up
« Reply #2 on: October 08, 2006, 07:24:06 PM »
I would think,
The idle goes up because of the load the headlights puts on the alternator, if you hook up a compressor, the idle should go up automatically when you turn it on, and it draws amps from the alternator.
94 SUZUKI SAMURAI / 1.6 8 VALVE TRACKER MOTOR.
Offline Skeeter
  • 23
Re: Idle-up
« Reply #3 on: October 08, 2006, 07:54:05 PM »
The problem is, if I adjust it to say 1500rpm, turn on compressor, it should work fine. BUT,I don't want it at 1500rpm every time I turn on the headlamps. I only want it that high when the compressor is on.
