Wheel spacers affect tires rubbing?
  • 2561 Views
Offline holman
  • 42
« on: October 04, 2006, 06:10:23 AM »
I have a 95 Tracker with OME springs and shocks and 1" coil sring spacers.I'm using 1" wheel spacers and my tire size is 235/75/15 with 7" American Racing Wheels.When I have my front wheels turned fully locked the tires rub on the  of the inner fender well.Is this do to the wheel spacers.I would like to run 30/9.5 tires.Would taking off the wheel spacers help my problem.
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
Re: Wheel spacers affect tires rubbing?
« Reply #1 on: October 04, 2006, 06:30:21 AM »
they should help on that, I know on my friends sammy doesnt rub anymore with spacers
« Reply #2 on: October 04, 2006, 08:52:59 AM »
Most probably, with the wheel spacers the wheel moves in a wider arc.
Offline WorkInProgress91
  • 31 gets it done
« Reply #3 on: October 04, 2006, 09:03:54 AM »
On stock wheels, if you try to run 31/9.50's without spacers they will rub on the frame.  since you already have aftermarket wheels, they're probably hurting more than they're helping.
91 sidekick
2'' B/L, 2'' coil spacers
31'' swampers
winch
custom bumper tank lift camouflage duct tape
« Reply #4 on: October 04, 2006, 01:59:36 PM »
Make sure to bang the ridge flat on the inside of your fenders.  That will usually give you a bit more space.  I also ran into rubbing against the bottom of the stock bumper.
Once I lifted my front end up with the spacers that took care of the last of the rubbing issues on the tracker with the 235/75's.  As WorkInProgress said though, the aftermarket wheels probably make the spacers unneccesary.
