transfer case locking up
  • 1759 Views
Offline DRAGGINZUZU
  • 141
« on: October 05, 2006, 02:09:59 PM »
my dads 87 samurai wont shift out of 2wd high is there some trick to this or is the transfer case shot? I thought I read somwhere wher thers a bushing that wears out?
Tony
Its not what you buy but what you build
 Tony
Offline Element
  • 1902
  • LillyKicker
Re: transfer case locking up
« Reply #1 on: October 05, 2006, 02:44:55 PM »
Rocky Road Outfitters:
http://www.rocky-road.com/zukdrive.html
The tcase 'sheet' is the bushing your transfer case shifter rests on. It can also be one major pain in the rear when it goes bad. Your transfer case will seize up and lock into neutral. You may or may not make it home from the trail after that. Our new high-density polyurethane sheet not only replaces the factory jobber, it will also last for longer than you own your vehicle... guaranteed! Don't just get another factory bushing from the other guys, pick up our lifetime bushing and never have to worry about this problem again
zUkTAH
U4WDA
