installing new coil springs
  • 2263 Views
Offline thisENDup
« on: June 22, 2005, 09:47:48 AM »
i'm trying to install taller coils in my 94 tracker, but its not working out too well. any hints on how to do it quickly and easily? (in the front)  :-/  my spring compresser doesn't seem to compress enough to get the old one out.
i did a search but didn't find what i was looking for.
(i'm also new here, so maybe i wasn't looking in the right places)   :-[
thanks in advance.
Offline Cwkick
  • 888
  • 6601
  • 68
Re: installing new coil springs
« Reply #2 on: June 22, 2005, 10:08:09 AM »
thanks in advance.
From the Gear Guide section this article shows one method for spring removal.
http://www.zukiworld.com/month_050103/feature_wheelers_spacers.htm
Good luck, Eric
Offline explosivo
  • 3157
« Reply #3 on: June 22, 2005, 10:14:00 AM »
if you can't get stock springs out, you're not removing enough stuff!
omghi2.us[/url]
Offline SuzukHunter
  • 70
  • CAN YOU SEE ME NOW??
« Reply #4 on: June 22, 2005, 12:10:52 PM »
you dont need a spring compressor to get them out or the new ones in for that mater. just a jack. ;)
how much taller are they then the stock ones.
remember one side at a time. unless your struts are inside the coils. if thats the case, i have never seen that on a suzuki before. stranger things have happened. ;D
Offline Natebert
  • 1098
« Reply #5 on: June 22, 2005, 04:56:37 PM »
A floor jack, some jackstands and 4 of your biggest buddies!
Jack up truck.
Rest on jack stands.
Put floor jack under 1 a-arm.
Have buddies sitting on hood, bumper, front seat, etc.
Put in spring, jack up a-arm until strut bolts can be tightened.
Say good bye to downtravel.
 ;D
