Oil,oil everyware!!!!
  • 2247 Views
Offline HUMZUKI
  • 117
  • Fool!
« on: January 21, 2005, 12:44:06 AM »
DAMN!!!!!! I just got to work (figured Id drive since I took the train all week and my trucks been sitting) and I could see from my desk window that there was some liquid under my truck. I didn't think anything of it till a co-worker said something about it. So I go out and look under and THERE'S OIL ALL OVER THE PLACE!!!!!!! It looks like oil just shot out of the oil pan gasket like it was under pressure. There doesn't seem to be any above the pan, just from it down. I checked the dip stick and its down to the bottom mark. Im always checking the level so I KNOW It Just happened. It seems like it has stoped for the most part, its just dripping off,,,,,,, EVERTHING,,,for now.
WHAT THE HELL just happened? Can an oil pan gasket just blow out like that? Maybe it was the front crank seal? :\\\'(
Offline Cwkick
  • 888
Re: Oil,oil everyware!!!!
« Reply #1 on: January 21, 2005, 01:20:42 AM »
Oil filter??
Oil pressure sending switch?
Cwkick
Offline HUMZUKI
  • 117
  • Fool!
« Reply #2 on: January 21, 2005, 02:15:43 AM »
I just had another look at it. Pretty Damn Sure its the crank seal.
I hope I can at least stop and fill, stop and fill,,,, it to get home. DAMN IT!!!!  >:( >:( >:(
« Reply #3 on: January 21, 2005, 03:38:59 AM »
stop and get a new pvc valve while your buying your oil, or clean yours. might help. also look at the back of the head to make sure that it is not your distributor o ring, they are known to leak like that.
« Last Edit: January 21, 2005, 03:40:39 AM by mrfuelish »
Offline HUMZUKI
  • 117
  • Fool!
« Reply #4 on: January 21, 2005, 05:03:30 AM »
Anybody know a trick to changing the front crank seal with out taking the entire engine apart? ;D :P
